Camber specs?
Old Dec 4, 2004 | 11:05 AM
Chaseme's Avatar
Default Camber specs?
I have 99' sedan EX. I've Eibach sportline springs, which are listed as delivering a drop of appr. 1.8" front and rear. I'm in serious need of camber kits. My camber is FL:-1.7, FR:-1.2, RL:-2.8, and RR:-2.4. I've been shoppping around for kits, but in order to know which one would be best, I need to know what the camber needs to set to. I want to try to correct some understeer inherent of any FF, so I was thinking -1 to -1.25 up front and -.5 to -.75 for the rear. So if anybody has any info, suggestions, or links, they would be greatly appreciated. Also, if you have found a particular setup with similar circumstances that has worked for you, you're more than welcome to share it.
I really want to get my camber issuses settled for two reasons. One: I've got some 15x7 slipstreams waiting to be installed. Two: I want optimize my handling. I was wondering as well what effect strut-top braces have handling? Would they aid in my goal of downplaying my car's understeer? Thanks in advance for help received.
Modified by Chaseme at 7:17 PM 12/4/2004
Old Dec 4, 2004 | 05:51 PM
Chaseme's Avatar
Default Re: Camber specs? (Chaseme)
bump
Old Dec 4, 2004 | 06:02 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chaseme &raquo;</TD></TR><TR><TD CLASS="quote">I'm in serious need of camber kits. My camber is FL:-1.7, FR:-1.2, RL:-2.8, and RR:-2.4.</TD></TR></TABLE>
Why? Only problem I see is the uneven settings from left to right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I want to try to correct some oversteer inherent of any FF</TD></TR></TABLE>
FF cars, and most mass-produced cars in general, are set up from the factory to understeer - not oversteer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I've got some 15x7 slipstreams waiting to be installed.</TD></TR></TABLE>
What does that have to do with your camber?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I want optimize my handling.</TD></TR></TABLE>
Then you'll want to keep your negative camber, if not add a little more. To find the ideal camber spec, you'll need a pyrometer to measure tire temps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering as well what effect strut-top braces have handling?</TD></TR></TABLE>
Realistically, none. They stiffen the chassis . . . and only marginally at that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Would they aid in my goal of downplaying my car's oversteer?</TD></TR></TABLE>
If you mean decreasing oversteer, then absolutely not. And neither will reducing the negative camber up front . . .
Old Dec 4, 2004 | 06:11 PM
Chaseme's Avatar
Default Re: Camber specs? (Targa250R)
Thanks. The reason I want to fix the camber is so when I put on the wheels and new tires, they don't wear unevenly. Why won't having more negative camber up front help out with the understeer?
SanJose408
Feb 23, 2009 03:42 AM
ncVTEC1313
Aug 19, 2008 09:07 PM
jdmdohcek98
Suspension & Brakes
Jan 13, 2008 06:35 PM
SMZ GSR
Oct 15, 2002 10:41 PM
2000si
Dec 12, 2001 10:44 AM
