Belt dressing
i sprayed some belt dressing on the belts today to make the little noise go away but i found that it increased it. is this normal or i should wait a bit to see the difference ?
if you sprayed ur belts and it just got louder.. that means its time for some new belts. It usually means that ur belts are so cracked or bad that the dressing just soaked into the cracks and prob made them expand more.
belts are only like 8 bucks anyway buy some goodyears and replace them
Check the pulley from whence the noise originates, 'n be sure its not your power steering pump suckin air. Try a small glom of gear oil on the teeth side.
accordcle
Nov 24, 2012 10:56 AM
CandyMamaRy
Jan 25, 2011 02:38 PM
MeanGreenEG9
Apr 9, 2003 07:38 PM
