Belt dressing
Belt dressing
i sprayed some belt dressing on the belts today to make the little noise go away but i found that it increased it. is this normal or i should wait a bit to see the difference ?
Re: Belt dressing (return_2020)
if you sprayed ur belts and it just got louder.. that means its time for some new belts. It usually means that ur belts are so cracked or bad that the dressing just soaked into the cracks and prob made them expand more.
belts are only like 8 bucks anyway buy some goodyears and replace them
Re: Belt dressing (IVI)
feel underneath the belts..they should feel kinda soft and rubbery..but if the
feel like the bottom of ur feet when they re drie d out..then the need replacing
Check the pulley from whence the noise originates, 'n be sure its not your power steering pump suckin air. Try a small glom of gear oil on the teeth side.
never spray belt dressing on belts
now when you change them your new belts will squeel unless you spend an hour geting all of the belt dressing off your pulleys
accordcle
11-24-2012 10:56 AM
CandyMamaRy
01-25-2011 02:38 PM
MeanGreenEG9
04-09-2003 07:38 PM
