bleeding air out of radiator
does anybody know how to bleed the air bubbles out of the radiator of a jdm itr motor? does it have a bleed screw?
if so can you provide pictures or say how i could locate it.
thanx
thanx
<FONT COLOR="green">Follow the upper radiator hose until it meets the head. Look for a 12mm bolt with a hole in the center. Loosen the bolt and tighten once air is removed.
The other way to do this-Start the motor when cold and remove the radiator cap. Turn on your heater and set fan at max speed. Let the car reach operating temp and put the cap back on when bubbles stop coming out.
You'll get the same result either way.</FONT>
TenaciousC
Aug 22, 2002 02:11 PM
