assembly lube
Old Dec 31, 2001 | 05:53 PM
S13 slide's Avatar
Default assembly lube
when putting the main and rod berings in, do you put some assembly lube on both sides of the bering? or just the side that touches the crank? thanks
oh and where else should i put the assy lube?
Old Dec 31, 2001 | 08:47 PM
Kataku2K3's Avatar
Default Re: assembly lube (bobo)
Just put it inbetween the crank and the bearing for both the cap side, rod, and block sides. Oh and if you're talkin about anywhere in the motor the cam journals will need some too if you have to remove the cams then put them back in.
[Modified by JDMspecEG6, 6:01 AM 1/1/2002]
Hatch3d
Aug 12, 2015 09:47 AM
2000BoostedEX
Aug 10, 2008 07:18 PM
AK77
Sep 20, 2007 06:42 PM
canuck-mx6
Jun 3, 2002 04:38 PM
