weak ass rear defroster
Old Dec 2, 2004 | 10:46 AM
user 98292739's Avatar
Default weak *** rear defroster
now during the fall and summer my defroster worked awesome. cleared up my rear window in mins. now its getting really cold and there is a lil ice on the rear window and my defroster cant seem to clear it out at all. it clears about 1/4 inch above and below each line. what could this be? not getting enough power? thx
Old Dec 2, 2004 | 12:08 PM
newtothascene's Avatar
Default Re: weak *** rear defroster (locovirus)
bump
i have the same problem
Old Dec 2, 2004 | 12:09 PM
efvader's Avatar
Default Re: weak *** rear defroster (newtothascene)
Mine is the same
Old Dec 2, 2004 | 12:11 PM
RobbieG35's Avatar
12 Years Strong
Default Re: weak *** rear defroster (efvader)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efvader &raquo;</TD></TR><TR><TD CLASS="quote">Mine is the same </TD></TR></TABLE>
Me too
Old Dec 2, 2004 | 01:44 PM
1RMDave's Avatar
Default Re: weak *** rear defroster (HybridHatch88)
same here.
Old Dec 2, 2004 | 02:08 PM
lilcasino's Avatar
Default Re: weak *** rear defroster (1RMDave)
same here, do they sell a replacement defogger grid?
Old Dec 2, 2004 | 03:02 PM
down_the_hatch's Avatar
Default Re: weak *** rear defroster (lilcasino)
my defroster doesnt work at all, theres power going to one side not the other side,
Old Dec 2, 2004 | 04:11 PM
NONVTECSI's Avatar
How bout scrapin' the ice off to get most of it off.
Old Dec 2, 2004 | 04:24 PM
KFBhonda's Avatar
Default Re: (NONVTECSI)
i don't know if this is your problem, but i also have a "weak *** rear defroster" so I went and bought a Rear Window Defogger Repair Kit. They sell 'em at most auto parts stores. It was less than $10. http://shop.store.yahoo.com/au....html
It's like the one in the link. You use it to "paint" any broken grids.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uglyasscrx &raquo;</TD></TR><TR><TD CLASS="quote">my defroster doesnt work at all, theres power going to one side not the other side,</TD></TR></TABLE>
I think it would work for you, uglyasscrx. Maybe?
Old Dec 2, 2004 | 04:39 PM
eda6's Avatar
Default Re: (KFBhonda)
I don't feel like typing, read my post on this thread
How to fix heat strips coming up later tonight
Old Dec 2, 2004 | 06:22 PM
well i was talking about ice on the inside...
Old Dec 2, 2004 | 06:59 PM
eda6's Avatar
Default Re: (locovirus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">How to fix heat strips coming up later tonight </TD></TR></TABLE>
1. locate the break in the heat strip. Clean are with steel wool then alcohol.
2. Put cellophane tape above and below the break.
3. use a brush to apply a coat of silver conductive paint. Dry 40 min.
4. Make sure you have 6V in the middle.
5. Apply 2nd coat and wait 4 hours remove tape.
Basically the same as the above kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locovirus &raquo;</TD></TR><TR><TD CLASS="quote">well i was talking about ice on the inside...</TD></TR></TABLE>
Maybe the heat stips can't defrost the ice because they don't put out enough BTU's (unit to measure heat=British Thermal Unit). It's a defogger not a deicer. Just a thought
Old Dec 4, 2004 | 09:45 AM
zephyr13's Avatar
How the hell can ice form on the inside?!
I think you just have on the outside if so. just pour some warm water over it. it works way better anyway. Don't be lazy and depend on the defogger.
Old Dec 4, 2004 | 10:14 AM
Stoich's Avatar
Default Re: (zephyr13)
use a voltmeter with the rear defrost on and find the one with highest resistance.
then locate tthe break and repair.
Old Dec 6, 2004 | 07:40 PM
this is what is weird.....i do get ice on the inside sometimes. when i have ice on teh outside it clears it away in like 5 mins tops. but on the inside it never really does just clears away lines....
Old Dec 6, 2004 | 09:01 PM
coot_er's Avatar
I love how the gut from cali says
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zephyr13 &raquo;</TD></TR><TR><TD CLASS="quote">How the hell can ice form on the inside?!
as if you can carry a hot bucket of water with you were ever you go
ice gets on in the inside because you have moisture in your car and then it gets on the glass and freezes. i think if you turn off your heat and roll the windows down for a couple of seconds before you park that the cold air clears out the moisture and you shouldn't have the problem as bad.
Old Dec 6, 2004 | 10:59 PM
Burlyirishdude's Avatar
Default Re: (coot_er)
simple physics and thermo rules...hehehe....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coot_er &raquo;</TD></TR><TR><TD CLASS="quote">I love how the gut from cali says
ice gets on in the inside because you have moisture in your car and then it gets on the glass and freezes. i think if you turn off your heat and roll the windows down for a couple of seconds before you park that the cold air clears out the moisture and you shouldn't have the problem as bad.</TD></TR></TABLE>
Yeah the rear defroster for me is working strong....i love it..... some of us got lucky...
Floyds_Customs
Feb 19, 2008 01:24 PM
iceman7329
18
Jun 19, 2007 09:50 AM
UgP
Jun 16, 2007 10:51 AM
Acuraman918
Aug 3, 2004 04:52 PM
Dan GSR
Sep 17, 2002 11:35 PM
