Meters in a N/A setup.... HELP
i plan to put in some meters.... but what are some good meters to put in a N/A setup???? i mean, other than Air / Fuel ratio... what are other important meter i should put in there.... thanks in advance...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinategra »</TD></TR><TR><TD CLASS="quote">what setup are you running? I run ls vtec and the two most important are oil pressure and a/f ratio</TD></TR></TABLE>
I have a h22 swap right now.... everything is just stock....
WIDEBAND A/F sensor
The $30 autometer one will just give you a light show. To get an ACCURATE reading, you need a Wideband O2 sensor setup from PLX, Innovative, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_joe »</TD></TR><TR><TD CLASS="quote">WIDEBAND A/F sensor
The $30 autometer one will just give you a light show. To get an ACCURATE reading, you need a Wideband O2 sensor setup from PLX, Innovative, etc. </TD></TR></TABLE>
thanks for the advice... i plan on getting the 3 pod what other meters should i get???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD »</TD></TR><TR><TD CLASS="quote">]coolant temp and oil pressure gauge.</TD></TR></TABLE>
i concur.. defi blackface.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries »</TD></TR><TR><TD CLASS="quote">
i concur.. defi blackface.</TD></TR></TABLE>
yea if your a baller. autometer, greddy work just as good
