piston rings
Old Dec 31, 2001 | 01:30 PM
S13 slide's Avatar
Default piston rings
when installing the piston rings on the pistons, which is which on the top two? one of them has a silver lining one the out side and the other one is all black. the helms says look for a chamfer but i dont see any, btw whats a chamfer? thanks
Old Dec 31, 2001 | 02:01 PM
blazin's Avatar
Default Re: piston rings (bobo)
The one that goes on top will have what appers to be a 45 degree angle cut on it's edge and the second one will have a small step cut into it.Hold the up to the light to see these things or use a mag. glass
Old Dec 31, 2001 | 08:13 PM
sgT's Avatar
sgT
Look for a marking on the ring.
The mark always goes up.
Old Jan 1, 2002 | 09:11 AM
earl's Avatar
Many times the two upper rings are a different thickness and are not interchangable in the ring lands. Normally the shiney chrome one goes on top as it sees the most heat, but don't guess. Look for a dot or some letters on the ring and they normally face up. If you put them in upside down, they won't work. Also be sure to check your ring gaps or you'll be tearing it down again. Once the ring is on the piston, it should spin freely in the ring land.
Boyle.R
Jun 21, 2014 12:38 AM
RACEPAK
Aug 30, 2008 09:59 PM
97grnrs
Feb 8, 2007 11:22 AM
Sliced Beard
Jan 22, 2004 06:55 PM
riceball777
Jan 17, 2004 09:41 PM
