question about CP pistons
i'm replacing pistons in a b18c1 block. currently the block has what's supposed to be 81.5mm, 11:1 CP pistons. there are some #'s on the back of each piston that say "79-2". the new pistons are CP pistons as well. they are 81.5mm and 12.5:1. on the back of these, the #'s say "81-2". see my problem? do these numbers indicate the bore size? if so, are the old pistons standard bore? any and all info is greatly appreciated.
Note:
Usually that number referes to the "smallest" bore size you can cut on that forging.
Shelf pistons and forced induction pistons uses these smaller forgings coz this gives you a thicker thus stronger skirt.
I_got_your_honda
Aug 17, 2006 01:04 PM
