B-20 BLOCK TURBO
Old Dec 1, 2004 | 05:16 PM
93 integra gsr's Avatar
Default B-20 BLOCK TURBO
CAN A B-20 BLOCK HANDLE UP TO 25 POUNDS OF BOOST WITH STOCK SLEEVES
BORED .5 A TOTAL BORE OF 84.5MM.
Old Dec 1, 2004 | 05:29 PM
Modified Motors's Avatar
Default Re: B-20 BLOCK TURBO (93 integra gsr)
hmm yeah you could probably put the boost controller at 25, just don't hit boost. From what i know which might not be much, but the b20 stock sleeves are weaker than the b18 stock sleeves.
Old Dec 1, 2004 | 05:36 PM
riceball777's Avatar
huh
no!!!!!!!!!
Old Dec 1, 2004 | 05:38 PM
hawjboi's Avatar
yes, the block can handle 25lbs but the sleeves r 2 thin and u will end up blowing ur motor. not a very good thing to do. if your goal is to use stock block and put a turbo kit on then 7-10lbs is sufficient. 25lbs is way to much for a stock b20.
Old Dec 1, 2004 | 06:01 PM
tegsallgood's Avatar
Default Re: B-20 BLOCK TURBO (hawjboi)
there is absolutely no way in hell that this would work.. sleeeeeeve. and what do you need 25 lbs of boost for ur **** better be fullllly built... like stated before 7-10 lbs will give u great power dpending on ur setup, but generally, and if ur planing on being that fast that you want 25 lbs, your gonna have to do a lot of work
Ct4754
Oct 11, 2008 06:24 PM
eats06702
Mar 23, 2008 12:12 PM
GoCarInteg
Nov 13, 2005 12:35 AM
Top Ramen
Apr 22, 2005 05:45 PM
gsr squirrel
Sep 17, 2002 09:13 AM
