Which BrakeLines Do I Use?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weston »</TD></TR><TR><TD CLASS="quote">I'm assuming you already have rubber lines installed... are they from an Integra or a Civic?</TD></TR></TABLE>
no i do not have the rubber lines installed. I am going to do the swap when my b16 motor and turbo go in. So everything will be done at the same time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">the ones for the caliper you are using</TD></TR></TABLE>
you use the brake lines for the caliper you are using.
if your using integra 94-00 non type R calipers you use those brake lines.
if your using integra 94-00 non type R calipers you use those brake lines.</TD></TR></TABLE>
sounds good. i was almost going to be 99-00 Si ones. but if integra ones will work. Then thats the ones im getting.
I would use the 99-si ones cause the teg ones don't have the same mount points on the front lines for the shock mount. the rear however should be the same between the 99-si and 94-tegs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smart monkey »</TD></TR><TR><TD CLASS="quote">I would use the 99-si ones cause the teg ones don't have the same mount points on the front lines for the shock mount. the rear however should be the same between the 99-si and 94-tegs.</TD></TR></TABLE>
SS lines are owned by Zip tie mounting
SS lines are owned by Zip tie mounting</TD></TR></TABLE>
sounds good.. Integra ones im gonna get.
mad props to the zip tie. i got itr lines on my ek/ls knuckles and im gonna zip tie them to the back of the knuckle because they are hella long
DOHCgarage919
Oct 8, 2007 04:38 PM
.BigSexy
Apr 8, 2007 05:42 PM
jefe
30
Dec 11, 2004 12:41 PM
