Have a problem with MUGEN program?
Old Dec 31, 2001 | 10:34 AM
714eg's Avatar
Default Have a problem with MUGEN program?
I have a 99 si I have headers, cam sprockets, fields vtec controller. My Idle is fluctuating. I rev it up to 2,000 rpm It will go down to 1,500 rpm and stops for a second and then idles normal @ like 800-700rpm. After I have been driving around for awhile I pull into my garage and the idle starts reving up and down constantly. I am assuming its because I don't have TYPE R cams. If any bodies knows anything pls respond.
Old Dec 31, 2001 | 10:39 AM
Spade's Avatar
Default Re: Have a problem with MUGEN program? (Teamvizine)
What happens when you put the stock ECU back on?
If same problem check your IACV or Map sensors along with any vaccum lines that may have been bumped showing off the engine.
Old Dec 31, 2001 | 10:49 AM
714eg's Avatar
Default Re: Have a problem with MUGEN program? (Spade)
When I put my stock ecu back in my car runs fine!
Old Dec 31, 2001 | 11:03 AM
Crazydave's Avatar
ok.. theres your problem
Old Dec 31, 2001 | 11:06 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Have a problem with MUGEN program? (Crazydave)
It's a bad burn. Get a new chip.
Old Dec 31, 2001 | 11:17 AM
714eg's Avatar
I have tried 2 different programs and they both do the same thing I am trying to figure out if its because my timing is not advanced alot people have been telling me that the mugen program you should advance timing 3 degrees.
Old Dec 31, 2001 | 11:22 AM
714eg's Avatar
My friend has the same program we put he's ecu in my car did the same thing.
Old Dec 31, 2001 | 02:54 PM
714eg's Avatar
I just talked to erick of erick's racing and he said I need a fuel pressure regulator for sure.
Old Jan 1, 2002 | 10:42 AM
Katman's Avatar
hmm..I've heard of this happening on Si coupes. I believe it has somthing with the wiring on the IACV. The 2 wires that go to the IACV plug need to be swapped around and that might fix the idle problem. I haven't tried this myself though (don't have any Si coupe owning friends who run an OBD1 conversion).
[Modified by Katman, 11:42 AM 1/1/2002]
douglas_be
Mar 24, 2004 09:18 PM
FSTVTEC
Sep 25, 2003 10:55 AM
vtecths
May 7, 2003 08:25 AM
sleeper4dr
Feb 10, 2003 05:43 PM
1.8T_EG
Aug 29, 2002 12:36 PM
