spark plug analysis?
Old Dec 1, 2004 | 10:57 AM
aaronhume's Avatar
Default spark plug analysis?
okay heres a picture of my old plugs I just replaced today. the two middle ones have a lot of ash build up on them. my best idea is that I am leaking oil in due to old valve seals.... any other ideas?
Old Dec 1, 2004 | 11:05 AM
AgentJam's Avatar
Default Re: spark plug analysis? (aaronhume)
looks like you may be running lean up top too.
Vince
Old Dec 1, 2004 | 11:19 AM
EF9Si-T's Avatar
I CAN'T SEE ****!
Old Dec 1, 2004 | 07:48 PM
SicRx's Avatar
goddamn son. yeah the oil thing and a fuel problem is what i think
Old Dec 1, 2004 | 08:14 PM
NFM_Dm's Avatar
Default Re: spark plug analysis? (SicRx)
my plugs look burned like that to but wtf is with plug 2? that **** looks melted.
Old Dec 1, 2004 | 08:58 PM
FULL-RACE EP3's Avatar
is this a stock motor?
Old Dec 1, 2004 | 11:00 PM
aaronhume's Avatar
Default Re: spark plug analysis? (Pooptooth)
yes this is a stock motor, never been rebuilt and has 235k miles on it...
the second plug is not melted thats just build up of that gray ash stuff...
if its running lean, how can I fix that?
Old Dec 2, 2004 | 08:04 AM
AgentJam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronhume &raquo;</TD></TR><TR><TD CLASS="quote">yes this is a stock motor, never been rebuilt and has 235k miles on it...
if its running lean, how can I fix that?</TD></TR></TABLE>
You're probably fine...do you run your car hard? race? Do you have intake/header/exhaust? which ones?
If you have bolt ons maybe you'd want a fuel pressure regulator so you can bump the pressure a few psi.
If it's totally stock i wouldn't worry about it.
Vince
Old Dec 2, 2004 | 09:32 AM
BigBooster's Avatar
you ever use a fuel or oil additive? if you are, then that's the problem. either that or the valve guide seals.
FalkenSiR's Avatar
Default Re: spark plug analysis? (AgentJam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AgentJam &raquo;</TD></TR><TR><TD CLASS="quote">looks like you may be running lean up top too.
Vince</TD></TR></TABLE>
These dpfi engines tend to run lean. These are the results after 230k miles of use. Just a fact. btw, no 2 looks bad man...
SinsEvil666
10
Jun 4, 2008 12:04 PM
el_toro_de_magnifico
Apr 15, 2008 11:13 PM
high_revs
Oct 30, 2005 01:01 PM
mongoliandonuts
Aug 27, 2004 11:51 PM
int3gra
Mar 6, 2004 08:57 AM
