Amps only work when on radio not CD
Old Dec 1, 2004 | 01:45 AM
cbrf-3's Avatar
Default Amps only work when on radio not CD
k i just installed a panasonic cq-c5410u and ive got 2 amps hooked up to it but they are only all working when its on radio. When i switch to cd or mp3 only the rears work, subs and front speakers are not playin anything. Any ideas on what that could be?
ive got jl audio components up front powered by amp and 2 6 1/2's in the rear runnin off deck power and 2 subs in the rear powered by 2nd amp
Modified by cbrf-3 at 11:27 AM 12/1/2004
Old Dec 1, 2004 | 05:30 AM
t0p_sh0tta's Avatar
Default Re: Amps only work when on radio not CD (cbrf-3)
Remote wire for amps is hooked up to antenna output on the deck. The turn on leads for the amps should be hooked up to the blue wire with the white stripe, not the solid blue wire.
Old Dec 2, 2004 | 07:41 AM
cd5_2NR's Avatar
Default Re: Amps only work when on radio not CD (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">Remote wire for amps is hooked up to antenna output on the deck. The turn on leads for the amps should be hooked up to the blue wire with the white stripe, not the solid blue wire.</TD></TR></TABLE>
yup..he's right...did this before...there should be another wire thats blue...
antok86
Audio / Security / Video
18
May 11, 2011 05:56 PM
civicgsr116
Nov 5, 2007 05:33 PM
XplodeTeg
Apr 6, 2005 09:56 AM
jerm001
Apr 18, 2004 08:48 PM
duppykiller1
Apr 11, 2003 05:41 PM
