How do you install cd player and amp?
Old Apr 8, 2003 | 03:51 PM
duppykiller1's Avatar
Default How do you install cd player and amp?
I am a noob at car audio but how do you install cd player and amp in a 90 civic hb? which wire is the remote wire to turn on the amp?
thanks
Old Apr 8, 2003 | 05:54 PM
CustomCJ00's Avatar
Default Re: How do you install cd player and amp? (duppykiller1)
the easiest way is to go buy a aftermarket wire harness to plug your factory harness into your new radio. the new wire harness then should match up color for color. The old radio comes out from behind with 2 8mm screws.
remote turn on for amp is usually blue or blue /white.
and please make sure u fuse your power wire to your amp under the hood.
run the wire through a grommet in the fire wall. Not through your door jam.
also have a good clean ground for the amp.
Old Apr 8, 2003 | 06:48 PM
Default Re: How do you install cd player and amp? (CustomCJ00)
Thanks alot for your info.
Old Apr 10, 2003 | 07:24 PM
Do you have to put a 0.5 amp fuse for the remote wire?
Old Apr 11, 2003 | 05:41 PM
ATF Kuk's Avatar
the remote turn on wire is blue and white.
lsjon
Audio / Security / Video
10
Apr 3, 2009 05:17 AM
4DRmafia
Mar 6, 2005 11:12 AM
cbrf-3
Dec 2, 2004 07:41 AM
jerm001
Apr 18, 2004 08:48 PM
IntegraBoy04
May 19, 2003 07:04 PM
