95 integra wire question
Old Apr 5, 2005 | 05:13 PM
XplodeTeg's Avatar
Default 95 integra wire question
On my pioneer radio harness, the remote wire is now used for remote to amp and antenna.(the previous owner got this work done) This is an odd split because my amp wouldn't get enough power. I looked at the pioneer website and it noted that the blue/white wire is for system control of power amp or power antenna. I want to do the antenna overide so i need to have a separate antenna wire. What can i do?
Old Apr 5, 2005 | 07:18 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: 95 integra wire question (XplodeTeg)
If I'm not mistaken, most radios have both a blue wire which is antenna trigger, and a blue with white wire which is amp turn on. if that doesn't work, try having someone wire a relay up on your remote turn on wire.
Chris
Old Apr 6, 2005 | 09:56 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XplodeTeg &raquo;</TD></TR><TR><TD CLASS="quote">On my pioneer radio harness, the remote wire is now used for remote to amp and antenna.(the previous owner got this work done) This is an odd split because my amp wouldn't get enough power. I looked at the pioneer website and it noted that the blue/white wire is for system control of power amp or power antenna. I want to do the antenna overide so i need to have a separate antenna wire. What can i do?</TD></TR></TABLE>The blue wire is 250mA, more then enough power to trigger the power ant. and turn on the amp, if you dont want the ant. up when you play CDs, just when radio is on, and your HU doesn't have the separate ant. amp trigger leads, just add an off/on switch to the power ant. trigger line. 94
bopbop93030
Audio / Security / Video
13
May 5, 2009 11:08 AM
civicgsr116
Nov 5, 2007 05:33 PM
sasser43
Jan 4, 2007 05:13 PM
sooo_slow
Feb 28, 2005 03:21 PM
Understeer
Apr 18, 2003 09:15 PM
