oil leak from where tranny meets the block
Old Nov 30, 2004 | 07:08 PM
c for sea's Avatar
Default oil leak from where tranny meets the block
beats me. i tried searching. sorry for the noobie question. tranny fluid is leaking i think.
Old Nov 30, 2004 | 07:11 PM
drdisco69's Avatar
Default Re: oil leak from where tranny meets the block (c for sea)
It's more likely the rear main seal on the motor or the oil pan gasket, if it's coming from in the clutch housing area. Make sure it's not coming from up higher though, or dripping from another part of the engine or transmission.
Old Nov 30, 2004 | 07:12 PM
Blaze45's Avatar
Brrraaaap!
Default Re: oil leak from where tranny meets the block (drdisco69)
If its not leaking form somewhere else... Im throwing in a vote for main seal...
Blaze
Old Nov 30, 2004 | 07:13 PM
krazie1's Avatar
BANNED
if it is there it most likely means two things
could be main seal is worn out which is pricey
this would mean motor oil leaking
or could be just a transmission output seal shot
this would be tranmission(red colored like) oil leaking
Old Nov 30, 2004 | 07:17 PM
eda6's Avatar
Default Re: oil leak from where tranny meets the block (krazie1)
Check the easy stuff first (Valve cover gasket, exhaust cam plug, vtec solenoid gasket).
Old Nov 30, 2004 | 07:32 PM
DaX's Avatar
DaX
Loved
Community Favorite
Auto or manual?
If fluid is red, it's ATF and is the input shaft seal.
If the fluid is oil, it could either be leaking from the engine or the tranny.
Old Nov 30, 2004 | 08:03 PM
c for sea's Avatar
it's a dohc zc. 5spd. using old rear main seal. that could be it. it's leaking from underneath. usng royal purple. same in the motor but 5w30. color is the same. my guess is the rear main.
Old Nov 30, 2004 | 08:04 PM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
Having the same problem with mines
I look under my car and I see oil/fluid all over the shift linkage.....ARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRGGGG GGGGGGGGGHHHHHHHHHHHHHHHHHHHH
Old Nov 30, 2004 | 08:11 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (c for sea)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c for sea &raquo;</TD></TR><TR><TD CLASS="quote">usng royal purple</TD></TR></TABLE>
If it started after you switched to that stuff, then it is probably from the oil. Keep in mind RP breaks down too fast, make sure you keep the OCI's around 2k mi.
Edit: Keep Honda MTF or Synchromesh in your tranny... Redline/RP Tranny fluid SUCKS.
slowpokesi's Avatar
Default Re: oil leak from where tranny meets the block (MR.RED'89)
i had the same problem with my zc but it wasnt the rear main seal, it was actually the input shaft bearing that was fucked up and it caused the input shaft seal to be fucked.
Ended up taking the whole tranny apart and replacing all the seals.
Just some advice, i wouldnt use synthetic oil in a transmission,
Old Nov 30, 2004 | 08:13 PM
mamaboy's Avatar
pull the motor and check both main seal and input shaft bearing. check around the hub/quill. your going to have to replace the clutch disc for sure
Old Nov 30, 2004 | 08:28 PM
^Sammy]!.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.RED’89 &raquo;</TD></TR><TR><TD CLASS="quote">Having the same problem with mines
I look under my car and I see oil/fluid all over the shift linkage.....ARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRGGGG GGGGGGGGGHHHHHHHHHHHHHHHHHHHH</TD></TR></TABLE>
My setup is z6 with (what I whought was a Si tranny but got jerked) I use castrol 10w40 high mileage oil with honda MT tranny fluid...had the axle seal replaced before cause it was leaking...this past weekend had the oil pan gasket cause that was leaking (and thought that was it)...but now I see fluid/oil redish all over the shift linkage....
Old Dec 5, 2004 | 11:04 PM
c for sea's Avatar
Default Re: oil leak from where tranny meets the block (mamaboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mamaboy &raquo;</TD></TR><TR><TD CLASS="quote">pull the motor and check both main seal and input shaft bearing. check around the hub/quill. your going to have to replace the clutch disc for sure</TD></TR></TABLE>
why the clutch disc?
Old Dec 6, 2004 | 04:07 AM
DaX's Avatar
DaX
Loved
Community Favorite
why the clutch disc?</TD></TR></TABLE>
The disc becomes impregnated with the leaking oil and deteriorates the braking surface. I didn't replace a disc once [this was in my Porsche] when I replaced my rear main, and a few weeks later had the entire disc shatter and had to take the whole thing apart again.
globy123
Jun 12, 2007 05:36 PM
TylerC
Aug 8, 2005 07:04 PM
TylerC
Aug 8, 2005 08:13 AM
danteisme
Jun 1, 2005 05:31 PM
B16CRXT
May 12, 2004 11:58 AM
