quick question bout this engine setup
Old Nov 30, 2004 | 06:20 PM
CRX_Control's Avatar
Default quick question bout this engine setup
d16y8 head(with crower cam),d16a6 block(stock) , d16a1 (p29) pistons . Think this set up will blow my engine? And if it will, what can i do to prevent it , any tips is good , thanks.
Old Nov 30, 2004 | 06:25 PM
FalkenSiR's Avatar
Default Re: quick question bout this engine setup (CRX_Control)
I think you are asking the wrong question.
Old Nov 30, 2004 | 06:27 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">d16y8 head(with crower cam),d16a6 block(stock) , d16a1 (p29) pistons . Think this set up will blow my engine? And if it will, what can i do to prevent it , any tips is good , thanks.</TD></TR></TABLE>
Hmm.....you are looking at one high compression motor, so if you want to keep it alive -
1) Don't rev it past what it is designed for
2) Get it tuned properly
3) Run high quality gas
4) Get it tuned properly
5) Stay up on maintance
6-10) Get it tuned properly
11) Don't cut corners.
Old Nov 30, 2004 | 06:29 PM
Default Re: quick question bout this engine setup (dr_latino999)
whould the results bear the same if i decided not to use the d16a6 block but the d16y8 block?
Old Nov 30, 2004 | 06:33 PM
If you used the Y8 block your compression ratio will stay the same as the pistons being used (P29s) and the combustion chamber are identical.
mrspeaker's Avatar
Heres a better idea.
Keep the stock a6 and use p29 pistons with a z6 headgasket.around 10:5:1.
Old Nov 30, 2004 | 06:36 PM
Default Re: quick question bout this engine setup (Mrspeaker)
bah, ima just get a crower cam. Thanks everyone.
LS-VTEC-TURBO-EF9
Jun 5, 2009 02:32 PM
Unseen Racer
Oct 7, 2008 06:56 AM
jhojhet
Sep 15, 2008 09:54 PM
JoseCuervo
Jun 25, 2005 03:09 PM
CRX_Control
Oct 20, 2004 02:58 PM
