Help with tranny problem, wont shift into 5fth or reverse
Old Nov 30, 2004 | 05:23 PM
jetpilot's Avatar
Default Help with tranny problem, wont shift into 5fth or reverse
Hi, I bought a JDM s1 tranny and when I put it on 1rst gear was in the position of 3rd gear, 2nd in 4rth, 3rd in 5th and 4rth in the reverse postion on the shifter. I disassembled the tranny and the shifter that should be in position to push the middle shift fork is angled and pushes the left shift fork
Anyone know how to fix this?? Can I use the shifter from a civic hydro or cable tranny (dseries)?? thanx in advance
Modified by jetpilot at 4:25 PM 12/1/2004
Old Dec 1, 2004 | 07:26 AM
jetpilot's Avatar
Default Re: Help with tranny problem, wont shift into 5fth or reverse (jetpilot)
ttt
Old Dec 1, 2004 | 12:59 PM
jetpilot's Avatar
I think its parts #4,6 and 8. Anybody else had this problem?? how did you resolve??
Old Dec 1, 2004 | 02:23 PM
PrettyLude's Avatar
i had the same problem before, turns out one of my shift forks were bent
Old Dec 1, 2004 | 02:49 PM
jetpilot's Avatar
ill try to snap a picture. All three shift forks are besides each other, aligned perfectly, they dont seem bent (ar they arent or all 3 are perfeclty bent to the right). On part #8 on the diagram the thing tat point outwards is what pushes and pulles the shift forks, it isnt centered when on neutral. thanks again
jvo8
Aug 11, 2024 07:12 AM
Hephro.T
Sep 27, 2016 11:22 PM
mmmbrapND
Transmission & Drivetrain
Apr 7, 2009 06:18 PM
boomslang
Nov 18, 2001 12:00 AM
