Bad VTEC Pressure Switch Cause Low Oil Pressure Reading?
Old Nov 30, 2004 | 11:30 AM
vtecb20coupe's Avatar
B A N N E D
Default Bad VTEC Pressure Switch Cause Low Oil Pressure Reading?
i've got a recently built ls/vtec and have been trying to monitor everything before really putting any miles on it. i'm getting a code 22 and will be replacing the vtec pressure switch tonight. could this bad sensor be causing me to have low oil pressure? i can only guess i'm getting low pressure because i'm using an autometer gauge(part # 4322) that only reads from 0-20 psi. there is not a 10 psi mark so i have only been able to guesstimate. the oil pressure light has not come on and i'm not looking for it to come on either.
is there any way i can test the pressure with another external source? i've only got like 6 miles on the car since rebuild so there's no way for me to check to see if vtec even engages.
also, does anyone have a soundclip or symptoms of a bad bearing or bearing outside of it's tolerances? i plastigauged everything and it was all within spec. i would hate to put the required mileage on the motor only to have to tear it down to replace a bad bearing.
any information is appreciated.
Old Nov 30, 2004 | 11:34 AM
egsleepercivic's Avatar
which oil pump did you use? vtec or ls? Possibly a bad gauge....
Old Nov 30, 2004 | 11:53 AM
B A N N E D
Default Re: (egsleepercivic)
it's a vtec pump, for a 99-00 si.
but regardless of the gauge, i'm more concerned with the switch to see if it relates to the low oil pressure.
Old Nov 30, 2004 | 12:09 PM
not sure.. but I think all the pressure switch does is tell the ecu it is ok to engage vtec, later jdm motors don't even have them, so i don't believe it would effect pressure... but I don't know for sure if this is how the switch functions
Old Nov 30, 2004 | 04:25 PM
B A N N E D
hopefully i'll get lucky and find something clogging the oil pickup. i just hope it's not a loose bearing.
anyone else have any ideas?
barone
25
Aug 20, 2009 08:32 AM
missionaryrider
Dec 9, 2007 01:50 AM
hellogsr
Oct 11, 2006 09:29 AM
Islander
Jul 7, 2003 03:15 PM
