Help!!! please for my 1.6 vtech honda
my engine had became weak its vtec doesnt seem to work and the egine check always light up when i rev up my car and the temp if rises up so high leas help me fix my honda i love my car i ont wanna sell it....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torch1986 »</TD></TR><TR><TD CLASS="quote">and the temp if rises up so high leas help me fix my honda i love my car i ont wanna sell it....</TD></TR></TABLE>
umm.what
umm.what
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torch1986 »</TD></TR><TR><TD CLASS="quote">my engine had became weak its vtec doesnt seem to work and the egine check always light up when i rev up my car and the temp if rises up so high leas help me fix my honda i love my car i ont wanna sell it....</TD></TR></TABLE>
why do you think your vtec is not working? does the engine light come on at the vtec engagement point? Is your car really over heating or is it just the thermostat?
I'd pull the CEL code, that will tell you why the light is on, also replace the thermostat, when it goes bad it can stick open and your guage reflects that you're overheating, it's a cheap part to replace and not hard to do at all. Hope this helps, good luck...btw your english is the suck imho
You need to get the code for that CEL. Could be oil pressure related or low oil? If the car runs hot and VTEC doesn't work (it operates on oil pressure) that could be a cause. Just a thought...
Cut the guy slack, it's his first post and he's in the Phillipines too.
Lord help us.
Lord help us.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downs »</TD></TR><TR><TD CLASS="quote">
Lord help us.</TD></TR></TABLE>
we're trying to help him, unlike you making sny remarks...
now go beg your lord for forgiveness asshat.....cause mine would kick your ***.
https://honda-tech.com/zerothread?id=682412
Follow the instructions in this thread. Then come back and tell us what you find so we can help you with your problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torch1986 »</TD></TR><TR><TD CLASS="quote">Help!!! please for my 1.6 vtech honda (torch1986)</TD></TR></TABLE>
Is it a 1.6volt vtech phone???
You guys with the Vtech phone jokes, how very original! Always ready to cut on someone but I never see you giving any help or advice related to the question. Maybe because you don't know anything more technical about Hondas than the guy asking the question. Big deal, you know how to spell VTEC!!! You probably had to go look at your stickers to make sure...
If you don't know anything that can be useful, don't post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SxualChkL8 »</TD></TR><TR><TD CLASS="quote">Is it a 1.6volt vtech phone???</TD></TR></TABLE>
shut up 16 post **** tard...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger »</TD></TR><TR><TD CLASS="quote">You guys with the Vtech phone jokes, how very original! Always ready to cut on someone but I never see you giving any help or advice related to the question. Maybe because you don't know anything more technical about Hondas than the guy asking the question. Big deal, you know how to spell VTEC!!! You probably had to go look at your stickers to make sure...
If you don't know anything that can be useful, don't post. </TD></TR></TABLE>
same to you dick.
__________________________________________________ __________________
i will take a stab at this.
1. check your oil level and make sure you get that code identified. https://honda-tech.com/zerothread?id=682412
2. check your overflow tank for bubbles while the car is running (1. start car...2. take the top off the over flow tank and keep it in the coolant...3. check for bubbles.). If you see bubbles that means your headgasket is slowing going bad and you need to change ASAP.
IF YOU HAVEN'T DONE MUCH WORK AS FAR AS TUNE UP'S ECT...
I would do your spark plugs, wires, timing belt, headgasket, oil change, valve adjustment, clear your code(s). BUT thats just me and i'm **** about my car
Modified by slowdx9585 at 4:03 PM 11/30/2004
same to you dick.
If you don't know anything that can be useful, don't post.</TD></TR></TABLE>
There are some things that he (the orginal poster) needs to do before posting, sure he's needs a lot of help but there are guidlines to follow and he's proviced NO info on his set-up. How can you even begin to diagnose his problem without knowing anything about his set-up. maybe he has a clogged cat, maybe he has a bypass filter that got sucked in and is clogging his t/b, maybe his engine is stock, or maybe he has 395,987 miles on his engine and hasn't changed the oil in 50k miles. Who knows, so any solutions you have are about as usefull as those vtech comments. you can throw idea's out all day and still not get close, why not cut to the chase and get the proper info first time around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx9585 »</TD></TR><TR><TD CLASS="quote">
same to you dick.</TD></TR></TABLE>
Why don't you read up all the posts, I posted earlier trying to help the guy. Hmmm, looks alot like the advice you gave later. I'm pretty sure I'm not the only one tired of the lame phone quip. If Bauley came in here he'd tell you the same thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid »</TD></TR><TR><TD CLASS="quote">
There are some things that he (the orginal poster) needs to do before posting, sure he's needs a lot of help but there are guidlines to follow and he's proviced NO info on his set-up. How can you even begin to diagnose his problem without knowing anything about his set-up. maybe he has a clogged cat, maybe he has a bypass filter that got sucked in and is clogging his t/b, maybe his engine is stock, or maybe he has 395,987 miles on his engine and hasn't changed the oil in 50k miles. Who knows, so any solutions you have are about as usefull as those vtech comments. you can throw idea's out all day and still not get close, why not cut to the chase and get the proper info first time around.</TD></TR></TABLE>
Yes the info is incomplete but it's enough to take a stab at a solution. Giving options that might or might not be the exact solution is still better than a snide comment or some other hateful remark.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx9585 »</TD></TR><TR><TD CLASS="quote">shut up 16 post **** tard...
same to you dick.
Modified by slowdx9585 at 4:03 PM 11/30/2004</TD></TR></TABLE>
You sure talk alot of ****. You need to lighten up. You just prolly had alot of people cut on you for the same thing and you're mad so you want to sound off like you're the ****. BTW I just got my Honda and any thing that I see that I can help out with I will. The 20 day trial user 5 post a day thing also limits posts too. Also, EAT ****!!!!
same to you dick.
Those of you bitching about other not being helpful...youre not helping.......
Here is how to check the CEL
http://www.hstuners.com/forums...23007
Did you connect all the wires for vtec, if it wasnt prewired for it?
Hows your coolant level? Do you have air in the system maybe?
When's the last time you had a tune-up?
xtreme-customz
18
Dec 1, 2005 07:51 PM
