ctr pistons
Old Nov 29, 2004 | 04:21 PM
b16bluef's Avatar
Default ctr pistons
looking to put ctr pistons in my b16a should i hone the block or just put the pisons in the moter has about 40,000 miles on it also my friend had a problehem with the pistons hitting the spark plugs ne one else had this problehem how do i get it to run right
Old Jan 7, 2005 | 09:02 PM
radteg's Avatar
i have ctr pistons on my b16, i would hone the cylinder cuz u need the new piston rings to seat with the walls...otherwise u might get blow by or what not...it pings a bit for me the higher octane u get the less it pings, with good spark plugs will help also.
Old Jan 7, 2005 | 09:05 PM
radteg's Avatar
u will also need to shave off a mill on the inside of the piston for the rod and the piston to go good... it doesn't cost that much at all just do it when u get the pistons and the rods together.
Old Jan 8, 2005 | 03:00 AM
function83's Avatar
Default Re: (radteg)
or mill off 1mm on each side off the rod to fit the piston.
SoldMyEM1
Oct 13, 2004 07:45 AM
10000rpm
Sep 20, 2004 02:27 PM
mist sITR
Feb 25, 2003 10:16 AM
One Bad GeeSeeR
Mar 4, 2002 10:23 AM
KayOs
Aug 17, 2001 11:22 PM
