higher compression= higher octane? help
Old Dec 30, 2001 | 03:49 PM
C4wrx's Avatar
Default higher compression= higher octane? help
whats our highest octane available? 95?
if i run somthing like 11.1, like in japan, here in the US we dont even have a high enough octain.
japan runs like 98?
basicaly what my question is, does anyone have 10.1 11.1 comp in their cars ?
dont tell me you use octane booster every tank
Old Dec 30, 2001 | 03:55 PM
fowler!'s Avatar
Default Re: higher compression= higher octane? help (Jdmb18c)
you didn't know? you must run octane booster for anything with compression over 10.5:1.
jfwy, you could safely go to 11.5:1 on 91 octane.
Old Dec 30, 2001 | 05:08 PM
CRX_VTEC's Avatar
Default Re: higher compression= higher octane? help (fowler yo!)
retard the timing if necessary
Old Dec 30, 2001 | 05:56 PM
killingtime's Avatar
Default Re: higher compression= higher octane? help (suprfast)
FYI - S2000 is 11.0 compression - on "premium" (91) octane
Demian
Old Dec 30, 2001 | 06:09 PM
KawiGreenVTEC's Avatar
Default Re: higher compression= higher octane? help (killingtime)
I run 11.5:1 compression on 91 Octane gas and advanced timing you will be fine, it's when you get near 12:1 you should start worrying although I know of people doing that on stock timing with no problems.
Old Dec 30, 2001 | 06:30 PM
eg6ajk's Avatar
yes Japan uses different rating then we do, we use whats called pump octane (AKI) system, they use something like RON system there is also MON system which combined together and avg. gives you pump octane...R+M/2=AKI
AKI= is used in USA (pump octane)
98 RON octane equal about 93-4 AKI at our gas station...
kidd_drastic
23
Feb 3, 2006 07:59 PM
christhereefer
Dec 27, 2005 10:00 PM
jeremy.
Apr 30, 2005 07:04 PM
B18G
16
Oct 28, 2003 04:10 PM
itr501
Mar 3, 2002 05:09 PM
