Squeakin belts
Old Dec 30, 2001 | 02:56 PM
Guitarzann's Avatar
Default Squeakin belts
I just got all my belts + timing belt replaced right before it got cold, maybe a month ago.
now all of a sudden i hear a little squeak right when i start up my car.... ????
Old Dec 30, 2001 | 06:17 PM
RedlinedVTEC's Avatar
Default Re: Squeakin belts (Guitarzann)
Your alternator belt is loose, loosen the top bolt that bolts the alternator to the block and pry the alternator back some. Then tighten the bolt up. Should be less than a 1/4" of deflection on the belt.
Old Jan 15, 2002 | 02:49 PM
Guitarzann's Avatar
Default Re: Squeakin belts (RedlinedVTEC)
its a d16z6 motor... aren't there 2 bolts i need to mess with?
i dont want to over tighten it..
Old Jan 16, 2002 | 11:06 AM
REDBARON's Avatar
It's only the top bolt. Just loosen it and put something in between the alternator and the block and make it nice and tight. Then just tighten the bolt. And I do have the D16Z6 engine also.
Old Jan 16, 2002 | 11:09 AM
Knightsport's Avatar
El Chico
25 Year Member
Community Builder
Community Influencer
Default Re: Squeakin belts (VTECHatch)
An easier fix is to take a bar of soap,readily available in your home,I hope. With the car running,hold the soap against the underside of the belt,or just use belt-ease.
It's easier than taking apart anything,unless you just want to.
Old Jan 16, 2002 | 12:49 PM
deepnite's Avatar
Default Re: Squeakin belts (Knightsport)
belt lube
Old Jan 16, 2002 | 01:07 PM
hensley's Avatar
Default Re: Squeakin belts (deepnite)
Tightening the belt is the best solution. Soap, belt lube and belt dressing work for a little while, then you replace the belt again.
Old Jan 16, 2002 | 01:11 PM
REDBARON's Avatar
Default Re: Squeakin belts (hensley)
Soap, dressing and anything like that will work, but only for a while. Plus you have to buy it. It's easier and cheaper to just tighten the belt.
Fo-Do Fanatic
Apr 7, 2010 03:59 AM
nemesiskrp
Apr 14, 2009 10:10 PM
lude1888
Jun 6, 2007 09:26 PM
GReddy212
Jan 30, 2005 03:42 AM
519[H]Si
May 25, 2004 09:25 PM
