NSX rear brakes?
Old Nov 28, 2004 | 09:47 PM
Solscud007's Avatar
Default NSX rear brakes?
I searched and found a lot of usefull info for Legend and NSX FRONT caliper upgrades on civics. However no one mentions the rear calipers. Do they fit? bolt placement is teh key component (I am hoping that all I need to do is the same for the fronts as the rears, which is grind the inner portion of the caliper bracket and redrill the NSX rotors to 4x100)
Old Dec 4, 2004 | 10:14 PM
FIGARILA's Avatar
Default Re: NSX rear brakes? (Solscud007)
im having the same problem aswell.... it seems the mounting points are way off????
Old Dec 4, 2004 | 11:02 PM
Airbag Club's Avatar
Default Re: NSX rear brakes? (FIGARILA)
i think it needs to have a braket retrofitted to make it work..
Old Dec 5, 2004 | 05:41 AM
Solscud007's Avatar
Default Re: NSX rear brakes? (Airbag Club)
So your saying they dont fit?
Old Jul 9, 2005 | 11:46 AM
pearlcfcivic97's Avatar
Fastbrakes.com has the rear brakes that you can buy, im not sure what they did to make it fit, and you dont have to re drill nsx rotors you can buy vw corrado rotors and they are the correct size and 4x100 as well
Old Jul 10, 2005 | 08:04 AM
timisyourfriend's Avatar
Default Re: NSX rear brakes? (pearlcfcivic)
mounting brackets are different... fastbrakes actually do not have them in stock, only the legend which are the similar 2 pot design as the nsx...
Old Jul 10, 2005 | 08:47 AM
Default Re: NSX rear brakes? (JZPerformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JZPerformance &raquo;</TD></TR><TR><TD CLASS="quote">mounting brackets are different... fastbrakes actually do not have them in stock, only the legend which are the similar 2 pot design as the nsx...</TD></TR></TABLE>
they dont have them in stock right now, or never will
Old Jul 10, 2005 | 09:04 AM
Redline96LX's Avatar
* B A N N E D *
please note stock rear discs on EG and EK models are like 9.4" and NSX rears are over 11" rears. Ive heard the only way to do it is rear NSX calipers, those corrado rotors (or NSX ones) and that bracket, cause there is no stock bracket to space that much. I'm gonna try making my own out of stainless steel in my friend's dad's machine shop via a milling machine, and a buncha other **** for metal works.
Old Jul 10, 2005 | 09:07 AM
Default Re: NSX rear brakes? (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">please note stock rear discs on EG and EK models are like 9.4" and NSX rears are over 11" rears. Ive heard the only way to do it is rear NSX calipers, those corrado rotors (or NSX ones) and that bracket, cause there is no stock bracket to space that much. I'm gonna try making my own out of stainless steel in my friend's dad's machine shop via a milling machine, and a buncha other **** for metal works.</TD></TR></TABLE>
thats going to be alot of work, id rather just buy it and know it will work, but youll be able to say that you made it... good luck
if your going to do this just make sure you have nsx ones in the front, if nto bigger or else when you slam on the brakes the rears will lock up first
Old Nov 29, 2008 | 07:29 AM
fc3srx729's Avatar
I think BrakeExpert sell's bracket's for the rear's...
popRAWvtec
Aug 26, 2005 12:43 PM
Solscud007
Dec 8, 2004 10:00 PM
BUKKAKE-ADAM
Nov 22, 2004 11:54 PM
