secondary o2 on a 99 civic?
Old Nov 28, 2004 | 04:50 PM
kyden's Avatar
Default secondary o2 on a 99 civic?
i have a 99 dx.. 99 b18b is in.. how do i wire in the secondary o2? the dx had it on the engine harness.. the ex/si have it on the dash harness..
Old Nov 30, 2004 | 12:05 PM
jungletronic's Avatar
Default Re: secondary o2 on a 99 civic? (kyden)
Assuming you are re-using your DX harness:
Extend the wires, and make sure to solder and use heatshrink. If you don't want to do that, DC Sports makes an O2 sensor extension which can be had for around $30 if I recall correctly.
Old Nov 30, 2004 | 07:50 PM
kyden's Avatar
Default Re: secondary o2 on a 99 civic? (jungletronic)
i am using an si engine harness.. so i think i have to wire it at the ecu, but i have no idea what wire goes where..
Old Dec 3, 2004 | 09:21 AM
kyden's Avatar
nobody?
Old Dec 3, 2004 | 10:03 AM
VTECVillain's Avatar
The EX/Si secondary O2 sensor plug and wiring is separate from the engine harness. You will need to hardwire it since you are using the Si harness. I can get you the proper pinouts to wire it up if you can't find them online.
Old Dec 4, 2004 | 01:54 PM
kyden's Avatar
Default Re: secondary o2 on a 99 civic? (VTECVillain)
i would appreciate that.
Old Jun 7, 2005 | 02:36 AM
kinvid22's Avatar
i'm having the same problem. I have a 98 DX, just installed a d16y8 engine and 96-98 EX harness. Can't plug the secondary O2 sensor to any plugs on the engine harness so I assume it's the same as above that I have to hardwire it to the ecu. Question is...what is hardwiring and how do I do it?
Old Jun 8, 2005 | 07:22 PM
powerfulperformance's Avatar
Default Re: secondary o2 on a 99 civic? (kinvid)
Okay this is how you do it. Jack up the car and look above the cat. you'll see a plug like plastic.....run the secondary o2 wire through there....extend the wire on the engine harness through the firewall and connect it....you'll get the idea.......
Old Jun 9, 2005 | 04:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinvid &raquo;</TD></TR><TR><TD CLASS="quote">Question is...what is hardwiring and how do I do it?</TD></TR></TABLE>
It means that you are running your own wiring and connecting the O2 sensor directly to the proper pinouts on the ECU.
Old Jun 9, 2005 | 09:39 PM
kinvid22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">It means that you are running your own wiring and connecting the O2 sensor directly to the proper pinouts on the ECU.</TD></TR></TABLE>
(viewed from the pin side on the male plug)
For the 96-98 OBDII ecu:
1 (green) goes to D13 (green/ blk) for sensor ground
2 (white) goes to D14 (white/ red) for sensor signal
3 (blk/white) goes to A5 (blk/ white) for heater signal
4 (blk/yellow) needs to "TAP" into A11 (yellow/ blk) for 12v power
So I make my own wires from the secondary o2 sensor, extend it long enough, and "splice" them into the engine harness wires right before the "A" and "D" plugs at these location: D13, D14, A5, A11 ???
Old Jun 11, 2005 | 11:04 AM
ballplayer's Avatar
do you have the ecu pinouts to an obd2b ecu? are they the same?
Old Jun 12, 2005 | 12:42 AM
kinvid22's Avatar
Default Re: secondary o2 on a 99 civic? (ballplayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ballplayer &raquo;</TD></TR><TR><TD CLASS="quote">do you have the ecu pinouts to an obd2b ecu? are they the same?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1196153
Old Jun 12, 2005 | 01:30 PM
hatch34's Avatar
just run a chipped p28 and you'll be all good
Old Jun 12, 2005 | 02:42 PM
ballplayer's Avatar
Default Re: secondary o2 on a 99 civic? (hatch34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch34 &raquo;</TD></TR><TR><TD CLASS="quote">just run a chipped p28 and you'll be all good</TD></TR></TABLE>
Not when you live in cali and you want to get your car bar'd
Old Jun 12, 2005 | 08:03 PM
kinvid22's Avatar
Not when you sold the car to your sister and you want her to have a legit car to smog
Old Jun 15, 2005 | 05:16 AM
dwnthehatch's Avatar
https://honda-tech.com/zerothread?id=1182033
stiffinEK
Mar 8, 2009 09:43 PM
ixoiiiiviviiivi
Apr 2, 2008 11:31 PM
team 15
12
Mar 29, 2007 06:03 PM
sleeperek
Oct 24, 2004 08:50 AM
mjrage
23
Aug 16, 2004 10:12 AM
