My dyno experience in detail
Old Nov 27, 2004 | 05:09 PM
DanishR's Avatar
Default My dyno experience in detail
I went to a dyno to tune my car. I had a Hondata setup but switched to Uberdata so I could tune it myself.
Here is the Hondata setup (scroll down): https://honda-tech.com/zerothread?id=826578
Power gaining mods:
Mugen intake
HyTech header and exhaust
RS Machines cams and valvetrain
Skunk2 cam gears
This is the Hondata setup on the dyno I used:
These numbers are flywheel hp. NOT whp. A stock euro ITR dynos at around 190-195hp on this dyno.
This is the Uberdata program I made on the road with a wideband. A/F is around 13,5:1
Gained 4-5hp compared to the Hondata setup that ran around 12-12,5:1 A/F in the top end.
Then, I changed the cam gears from (+2,0) to (+3,0) and got this:
Gained before around 7400rpm, lost 3 hp over that point. Continued with the lower peak number graph. Nice low end and mid range gains...
Changed cam gears to (+3,+1), but that didn't do much:
Changed cam gears to (+3,-1) and got this:
It is not compared to the correct graph. Learning to use the dyno software, operating a dyno and tuning for the first time is not easy It did give better peak numbers though.
Then I added 2 degrees of timing using Uberdata in the entire rev range and gained power up to about 7k rpm, and lost some after that. Didn't take a picture...
So, I removed 4 degrees of timing above 7k rpm (total -2 compared to stock GSR bin file) and got this:
Again compared to the wrong one, but better peak numbers
Then, I removed 1 degree above 7k rpm:
Not much of a difference...
Another -2 degrees above 7k rpm:
Another -1 degrees above 7k rpm:
Stopped after that.
If you look closely I actually lost a little power from 7-8k rpm by pulling out timing on a couple of the runs. I didn't notice that when I was at the dyno, so I just added 3 degrees from 7-8k rpm afterwards. It should have been set up to show different colours, so you couldn't make this mistake...
This is the before/after from the changes:
I am pretty happy with the gains. Not a huge amount, but I had fun using Uberdata and the dyno
What do you think?
A little in car vid:
http://www.we-todd-did-racing....DE%3D
See, it's still too slow
Modified by DanishR at 1:21 AM 11/28/2004
Old Nov 27, 2004 | 05:42 PM
nightrider's Avatar
Default Re: My dyno experience in detail (DanishR)
so much dyno time.
Old Nov 27, 2004 | 08:09 PM
uNF$@#!'s Avatar
good thing you mentioned that chart is in flywheel hp otherwise the gremlins of the itr forum might jump on your bones for posting this
Old Nov 27, 2004 | 08:39 PM
b19coupe's Avatar
So about 30 flywheel HP with bolt-ons and tuning? Very nice
Old Nov 27, 2004 | 10:56 PM
xprohx's Avatar
I think too much
Default Re: My dyno experience in detail (b19coupe)
Excellent, nice smooth curves with no glitches...
Old Nov 28, 2004 | 12:18 AM
DanishR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">So about 30 flywheel HP with bolt-ons and tuning? Very nice </TD></TR></TABLE>
There was 30 flywheel hp with the intake, header, exhaust and tuning.
Then another 10-12 flywheel hp with the cams and tuning.
It was about 5 flywheel hp weaker when it was stock than 2 other ITR's for some reason...
Modified by DanishR at 2:16 AM 11/28/2004
Old Nov 28, 2004 | 01:22 PM
Mr.OB*GYN_Rhett's Avatar
very nice, sounds awesome
mdj_ge
Nov 21, 2004 12:35 PM
sk!tz0
Jun 10, 2003 07:07 AM
xXx Justin xXx
May 13, 2003 12:07 PM
Type-Rare#1248
Apr 29, 2003 06:33 AM
GOKOU
Oct 9, 2002 06:33 AM
