HELP!! ABS light on.
I don't know why my abs light is on. What can i check to see if everyting is ok? i unplug the abs pump recently and plug it back up (just the plugs). it's all plug in now. i also took out the front brake rotor before it happen. Any idea how to fix this problem.. thanks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR0186 »</TD></TR><TR><TD CLASS="quote">I don't know why my abs light is on. </TD></TR></TABLE>
What trouble code does it have stored?
i have a 01 type r with a k20a swap in it. i cant read any code yet because the link connector is not hooked up yet. just did the axle, can that affect anything?
If you have the wrong axle, the sensor wheel may be incorrect, or plain missing. Did it have the sensor teeth on it?
Once you get the DLC hooked up, things will be a lot easier.
the axle does have the teeth on them, they look very similar to the jdm one. i got these axles from hasport. i know i need to hook up the DLC asap but the problem is... i don't know how too..
siblue_gzer
Aug 13, 2007 12:17 PM
