b20 block ls head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilsimsli »</TD></TR><TR><TD CLASS="quote">anyone do a b20 block with ls head would it be a hassle like an ls vtec with oil lines and stuff. also any dyno runs on this setup</TD></TR></TABLE>
LS head is the same casting as the B20. Only difference between the two are the cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CaRzY AsIan »</TD></TR><TR><TD CLASS="quote">so which cam ( ls or stock) will be best for b20z</TD></TR></TABLE>
LS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CaRzY AsIan »</TD></TR><TR><TD CLASS="quote">and which trainy with be better for b20z (ls or b16)</TD></TR></TABLE>
A B16 tranny on an LS rips for sure, but if you do a lot of freeway driving then I wouldn't suggest it because of the constant higher RPM's.
LS
