[FAQ] How to Re-wire Your Honda for VTEC
Old Nov 27, 2004 | 07:14 AM
unbelievableEG's Avatar
Default [FAQ] How to Re-wire Your Honda for VTEC
from http://www.hondaswap.com
Ok, assuming you have a vtec motor in a non vtec car and you need to wire in vtec y0! here it is...
Our demonstrator model is a 95 CX with a OBD I B16A. So you have your motor in the car, and you are using XXXX engine harness, as long as you have the plugs (usually come with motors harness, even JDM, just remove the whole thing from sensor/solenoid, to canon plug from the harness)) you're good. First you need to run the wires...
BLU/BLK and GRN/YEL from here...
To the canon plugs (shock tower connectors)...
Now, if you are using the vtec harness there's no need to remove them as there should be nothing plugged into the connector on the other side (on a vtec car, such as a VX, or 92-93, this part is over, as it will have them already) the wires should match up to empty slots. But if there is something on the other side, simply remove them (vtec wires) to an empty slot with nothing on the otherside. For the cabin side of the canon plug, you need to get the pin from the canon plug, to the ECU (junkyard). you need to get enough pins from a junker to connect whatever you are connecting.
Anyway now you have the wires going from the vtec solenoid, to the canon plug and out the other side...
Now, make sure the wire coming out of the cabin side of the canon plugs is long enough to go through the firewall, and to the ECU.
For the ECU connections same as the canon plugs, you need to acquire the pins. You can pull these out of a junker also. All the pins from the same generation are the same (there are two different sizes in each plug, you'll be using the smaller ones), and I was told that they are all the same from any model, and probably all generations, but I won't swear to it.
Here's how to remove the pins from the ECU...
If you want to take the time, you can pull the wire al the way from the ECU plug, to the canon plug, but I just splice a couple together, it saves a lot of time.
Here is what you should have...
The ECU slots on the non vtec models should have nothing in place, just a hole. At this point you should know where the pins go A4, and D6, so what are you waiting for, plug them in already...
Any time you need to splice wires together, I suggest soldering them when done, if you can't, at least use a good male/female plug, I like these...
Now, you should have vtec y0!, drive around let your car warm up and then let it rip (provided you aren't still throwing a CEL code). If everything is kosher, bolt in your ECU, wrap everything up, and blend it into your harness for that nice clean look.
You can also by pass the canon plug, and run a hardwire all the way from sensor to ECU, this works to, but doesn't look as clean.
Here is some more wiring pics, to give you some ideas. In the first one, I am using a VX harness (5 wire o2) on a B16A (four wire o2) in a CX (1 wire o2) so I had some issues . Anyway, after figuring out what wires were what, I used my handy connectors and connected...
For the switched 12V, I used the plug full of YEL/BLKs on the driver side, that goes to the main relay (thanks Poison), and spliced into one of the wires, then ran it to the o2 taping it into the harness once it was all connected, running right...
dont forget to plug the canon plug back in or else vtec will not engage.. once you've finished run the car and drive around, make sure the comptuer isn't throwing out anymore codes then let her rip
Modified by unbelievableEG at 3:12 PM 11/27/2004
Old Nov 27, 2004 | 07:19 AM
Luserkid's Avatar
Default Re: [FAQ] How to Re-wire Your Honda for VTEC (unbelievableEG)
Very clean and sexy how to from a 04. Way to go
Old Nov 27, 2004 | 07:30 AM
-Gambit-'s Avatar
Default Re: [FAQ] How to Re-wire Your Honda for VTEC (Luserkid)
awsome write up
Old Nov 27, 2004 | 07:32 AM
HybridEJ1's Avatar
If you're going to copy information from another site, you should at least give them credit.
Old Nov 27, 2004 | 02:45 PM
93CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unbelievableEG &raquo;</TD></TR><TR><TD CLASS="quote">from http://www.hondaswap.com</TD></TR></TABLE>
Old Apr 22, 2005 | 07:49 AM
92b16vx's Avatar
Default Re: [FAQ] How to Re-wire Your Honda for VTEC (HybridEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">If you're going to copy information from another site, you should at least give them credit. </TD></TR></TABLE>
Or at least make sure it hasn't already been posted here by the creator...https://honda-tech.com/zero...19292
Old Apr 22, 2005 | 08:16 AM
Deemeetree's Avatar
Electrician
Holy ****, an exact same thread with the exact same pics. ******* thief.
Eg_TypeR
Jul 2, 2007 07:13 PM
projecthonda
Feb 23, 2007 06:48 PM
Mr. Roboto
Dec 10, 2006 06:59 PM
92b16vx
Apr 25, 2005 01:18 PM
Naoh_97
10
Feb 14, 2005 10:40 AM
