What lube to use?
Old Nov 26, 2004 | 10:25 PM
megaman096's Avatar
Default What lube to use?
I have come to the conclusion by searching a problem I have that I need to lube up my slave cylinder. A few questions: What all types of greases(lubes) whatever should I use, and which types should I stay away from. How far do I peel back the boot? My dad brought some type of grease home from his work, it is a thick gunky kinda type grease, some type of high heat moly and lithium grease. Yet it may be hard to put way back in the boot since the only way to apply the thick stuff is with your finger? Thanks.
Old Nov 26, 2004 | 11:44 PM
BatuKing's Avatar
Default Re: What lube to use? (megaman096)
I would use some kind of synthetic grease, like sil-glide or brake grease.
you shouldnt need much and the only points you will need is outside of the slave cylinder, where it touches the fork, inside dont lube it since there is a seal like a wheel cylinder and its not designed to be lubed other then the fluid from the clutch master cylinder.
Old Nov 27, 2004 | 01:05 AM
_Cyclone_'s Avatar
Ahh... I think I have the same problem you have... I will be doing this soon as well.
Don't use your finger in the grease... use an old toothbrush. This works for me
Old Nov 27, 2004 | 01:23 AM
junek00's Avatar
KY gel!!! lol
Old Nov 27, 2004 | 08:07 AM
f1z1c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by megaman096 &raquo;</TD></TR><TR><TD CLASS="quote">.......... My dad brought some type of grease home from his work, it is a thick gunky kinda type grease, some type of high heat moly and lithium grease. Yet it may be hard to put way back in the boot since the only way to apply the thick stuff is with your finger? Thanks.</TD></TR></TABLE>
That sounds like wheel/axle grease. Im sure its suitable for brakes. A grease gun is the easiest way to lube using grease tubes with the pointy end, or get a pneumatic gun with a universal lube fitting, that would work too under the boot.
Old Nov 27, 2004 | 09:03 AM
megaman096's Avatar
Default Re: What lube to use? (f1z1c)
I see the slave cylinder but I have no clue on where to lube and what to pull back, does anyone have any pictures or could get some? Thanks for everyones help so far.
Old Nov 27, 2004 | 09:11 AM
BatuKing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by megaman096 &raquo;</TD></TR><TR><TD CLASS="quote">I see the slave cylinder but I have no clue on where to lube and what to pull back, does anyone have any pictures or could get some? Thanks for everyones help so far.</TD></TR></TABLE>
YOU DONT LUBE THE SLAVE CYLINDER PERIOD&gt; if it leaks then you need a new one.
Old Nov 27, 2004 | 09:24 AM
megaman096's Avatar
Default Re: What lube to use? (BatuKing)
??? It doesnt leak but how do I go about doing what everyone else is doing because my clutch squeaks and moans and I want to try lubing up the slave cylinder like I have read around these boards because it might be a fix. Or is it he clutch fork?outside of the slave cylinder, where it touches the fork. &lt;&lt;&lt;Where is that at?
Old Nov 27, 2004 | 09:21 PM
BatuKing's Avatar
Yes it is where it touches the fork, and also it could be the throw out bearing or pilot bearing
meanEG
Welding / Fabrication
Dec 30, 2007 01:44 PM
tnord
30
May 28, 2005 07:57 PM
devilpuppy
Jan 26, 2005 11:31 AM
Apocolipse269
13
Nov 9, 2004 07:52 AM
00civicvtec
Aug 24, 2002 10:55 PM
