separating tranny from block - 2000 si
I have a 2000 Si and I pulled my motor/tranny. I want to send the block to the machine shop but first I have to remove the tranny and strip it down. However I am unable to separate the tranny from the block. I have done this before to change a clutch, but the motor was still in the car.
Can someone please give me a tip on how to do this with the motor out of the car already?
Thanks !!!
Thanks !!!
Re: separating tranny from block - 2000 si (nissanjon)
Grab a friend and he holds the engine, you hold the tranny and you wiggle and pull. Also try using a flat head screwdriver and pry it apart. It should come out. Some are harder than others
Re: separating tranny from block - 2000 si (xtremeazian)
don't forget the three bolts under the trans 2 are 12mm the other I think is a 10
also do'nt forget the starter also has one long bolt that goes through the trans and into the block
Re: separating tranny from block - 2000 si (sans)
you guys are awesome, that's just what i needed to hear.
thanks to you, the motor and tranny are apart.
http://www.getrealmail.net/~nissanjon/mess.jpg
also, just thought i'd share a pic of my ORIGINAL clutch, after 172,000+ miles. Still got a little grip not much, but I have seen much worse with much fewer miles....
http://www.getrealmail.net/~ni...k.jpg
