No Go on the hondata.
Well heres the deal i bought a s200b system to run with my turbo setup, right now i dont have all my parts so i figured why not install the hodata and play with the 3-step and what not...so i went down to the shop and had our guy burn me a stock chip for my car and added 5% fuel across the board because i got an intake header and exhaust which should flow a hair better so why not...anyways i hook it all up and its idling at like 2500 rpm and throwin a CEL also i tried to give it a little gas and it kinda bogs unless you REALLY ease into it...the chip is installed the right way with the arrow/notch pointed towards the wiring harness, and the hondata unit does come on with a steady red light... any ideas?
check the code like u would normally thru the service connecter right passenger side kick panel u have 2 jumper it put key in turn key one don't start the car the light should flash hondata only has 10 codes that it throws should not be that many
