Help with Si Cluster. (Tach Not working) SEARCHED
swaped the dx cluster for a si. I have a autometer tach in it right now along with the si cluster...the cluster worked fine from the car i got it out of. What could be the prob? stock wire apart from the dizzy? do i need to hook the blue wire on the dizzy i have to my autometer hooked up to..????????help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 918-Hatch »</TD></TR><TR><TD CLASS="quote">swaped the dx cluster for a si. I have a autometer tach in it right now along with the si cluster...the cluster worked fine from the car i got it out of. What could be the prob? stock wire apart from the dizzy? do i need to hook the blue wire on the dizzy i have to my autometer hooked up to..????????help</TD></TR></TABLE>
When you hooked up the autometer tach, how did you do it?
You might have cut the blue tach wire between the dizzy and firewall when you hooked the Autometer tach instead of tapping the wire. Make sure your blue wire is connected to your dizzy.
99sibluehatchwitb16
Jan 26, 2006 12:47 AM
EF'IN NUTS
Mar 27, 2004 08:53 AM
rody084
12
Dec 30, 2003 08:52 AM
