LS/VTEC QUESTION
Would it be better to keep the stock crank w/ itr pistons and rods..or should I use a gsr crank w/ itr pistons and rods...or if anyone has any suggestions let me hear thanks in advance for any info provided
Using the GSR crank would eliminate half of the concept of the LS/Vtec. That half being you would shorten the stroke since the GSR stroke is shorter than the LS. I don't remember the outcome of the R rods with LS crank a deck plate might be needed. If you use a Vtec head on a B18B block with GSR internals you have a GSR motor minus the oil squirters and girdle. You need to do research and not try to be spoon fed the answers are all over the internet and on Honda-Tech.
dominicanvtec
Mar 9, 2005 11:19 AM
