3inch intercooler piping???
Old Nov 25, 2004 | 09:00 PM
jdmfun99's Avatar
Default 3inch intercooler piping???
Is 3 inch charge piping worth it on a car above 500 horsepower? Will it make a difference?
Thanks
Old Nov 25, 2004 | 09:47 PM
AspectIndustries's Avatar
Default Re: 3inch intercooler piping??? (jdmfun99)
Ive seen guys make 500whp-600whp+ all the time with 2.5" pipings.. Assuming its not really nessecary... But what do I know..
Unless you got a large Throttle Body, or large a Turbo compressor having a 4" outlet..? Then It might be fun... B
Old Nov 26, 2004 | 08:50 AM
RyanEJ8's Avatar
Stick with 2.5" piping.
Old Nov 26, 2004 | 11:36 AM
XxRoCkMaNxNEOxX's Avatar
Default Re: 3inch intercooler piping??? (RyanCivic2000)
i hear that going 3" from the cold side is good. u can go w/ 2.5 or 2.25 on the hotside
Old Nov 26, 2004 | 11:44 AM
Unsivil_audio's Avatar
I dont have really any evidence to back this up, but I've always said never use piping bigger than your throttle body. But I think it makes sense you're only gonna cause turbulence reducing size to your throttle body, and larger pipes take longer to pressurize therefore it takes longer to pressurize your intake manifold, effectively increasing spool time.
Old Nov 26, 2004 | 12:18 PM
MooreBoost's Avatar
Default Re: (Unsivil_audio)
I wouldn't go any larger than your TB.
Old Nov 29, 2004 | 01:52 PM
jdmfun99's Avatar
Default Re: (tegunderpressure)
i have a 68mm Ericks Racing throttle body....thanks guys..keep coming
Old Nov 29, 2004 | 03:15 PM
dasher's Avatar
Default Re: (jdmfun99)
68 mm = 2.7"
.. so don't go larger than this on the upper IC pipe ... I would keep the lower pipe at 2.5"
or get a 70mm TB and go 2.5 " on the lower and 2.75" on the upper IC pipe ...
only If I want around 600whp
Old Nov 30, 2004 | 03:28 PM
jdmfun99's Avatar
Default Re: (dasher)
anybody else?
Old Dec 1, 2004 | 05:07 PM
jdmfun99's Avatar
HELLO
Old Dec 2, 2004 | 08:22 AM
vtecdamian's Avatar
im 2.5 and 3 inch
Old Dec 2, 2004 | 08:58 AM
This One's Avatar
Default Re: (vtecdamian)
I run 3" on the outlet side of the I/C and 2.5" on the inlet side on my personal car.
No reasoning behind it really, just happened to be what i had around when i built it all. I haven't really had any problems with it. Car only makes 300whp as it sits right now.
I generally use 2.5" on most of the stuff I build and It all seems to work well
Old Dec 3, 2004 | 05:49 PM
Mike@CCT's Avatar
Formerly Mike@TSR
where can i buy the 2.5" hot side and 3" cold side piping?
Old Dec 3, 2004 | 06:00 PM
jdmfun99's Avatar
Default Re: 3inch intercooler piping??? (1320project.com)
custom make it?
Old Dec 6, 2004 | 02:32 PM
jdmfun99's Avatar
ttt
Old Dec 6, 2004 | 02:36 PM
MooreBoost's Avatar
Just stick to 2.5, why fiddle with something that is tried and true?
BB6-213
Dec 9, 2006 03:26 PM
dmecarboy
Aug 8, 2003 05:55 AM
pub
Mar 23, 2003 12:10 PM
DIY_Racing
Dec 26, 2002 08:59 AM
Blown90hatcH
Aug 30, 2002 12:22 AM
