Do I need tochange axles when converting to ITR brakes?
Old Nov 25, 2004 | 06:52 PM
dpine's Avatar
Default Do I need tochange axles when converting to ITR brakes?
I am thinking about converting over to 96 spec ITR suspension on my 95 civic coupe. It has the stock d series in it. Do I need to change the axles?
thanks
Old Nov 26, 2004 | 09:10 AM
dpine's Avatar
Default Re: Do I need tochange axles when converting to ITR brakes? (dpine)
anyone?
Old Nov 26, 2004 | 12:13 PM
dpine's Avatar
anyone? 96 spec itr sus.
Old Nov 27, 2004 | 05:42 PM
Katman's Avatar
no, you dont need to change axles, you can keep using your exsiting axles with US ITR 5lug conversion. Altho, there would be a problem if you wanted to use 98+ JDM ITR 5lug (uses a 36mm axle spline).
Old Nov 28, 2004 | 10:40 AM
dpine's Avatar
Default Re: (K@man)
does the itr 4X114.3 suspension use 36mm axles like the jdm 5 lug?
Old Nov 28, 2004 | 11:57 AM
Katman's Avatar
Default Re: (dpine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpine &raquo;</TD></TR><TR><TD CLASS="quote">does the itr 4X114.3 suspension use 36mm axles like the jdm 5 lug?</TD></TR></TABLE>
nope.
Old Nov 28, 2004 | 12:57 PM
dpine's Avatar
Default Re: (K@man)
So bacically your saying I can use the 4X114.3 itr suspension on a 95 civic with a d series motor and not have to change the axles.
Are there any differences between manual trans axles and auto axles? its an auto civic.
Old Nov 28, 2004 | 01:03 PM
dpine's Avatar
Default Re: (dpine)
thanks k@man for the info
hondaon18's
Jul 9, 2010 05:58 PM
2tonedc2
May 22, 2008 03:42 PM
frankenstein ek9
Apr 5, 2008 10:52 AM
snowboardgeek1
10
Sep 4, 2007 09:07 PM
Terrible One
Mar 19, 2005 06:19 AM
