Rattling noise and it's VERY annoying.. Please help!
Old Dec 29, 2001 | 03:21 PM
boost killz's Avatar
New User
Default Rattling noise and it's VERY annoying.. Please help!
Hey guys I need some opinions of what this problem can possibly be. Symptoms are as follows: Basically at idle th car is idling fine no probs but there is a rattling noise for instance if you hold a playing card to bicycle spokes and it seems to be coming from the passenger side in the front. If I accelerate it the sound goes accordingly with the acceleration of the car and gets a little high pitched but slightly. The only way it seems to shut up is when I barely engage the clutch and I mean barely and has me possibly believing it's the throw out bearing but wouldn't get why the sound gets fast and louder with applying gas at idle or while accelerating on the road. Please help guys. I know it's not FI but alot of the guys here know just about all the aspects of an integra besides just turbo and hope you can help me out, TIA
Nick
Nick
Old Dec 29, 2001 | 10:22 PM
1fstevo's Avatar
New User
Default Re: Rattling noise and it's VERY annoying.. Please help! (boost killz)
So, noise appears and disappears by engage and disengage the clutch??
Does it make noise while gears in neutral? is if does, did noise get faster as you rev the motor in nuetral?
Need more input to crunch out possiblility...
Are you sure it's not some plastic under the fenders scraping away on your tire? I seen alot of those.
Old Dec 29, 2001 | 10:53 PM
New User
Default Re: Rattling noise and it's VERY annoying.. Please help! ([Evo]Hybrid)
Yes the noise did get faster as I gassed the car while in neutral but would be gone if I barely engage the clutch pedal. Thanks,
Nick
Old Dec 30, 2001 | 12:00 AM
1fstevo's Avatar
New User
Definatly something to do with the clutch.
What about fully engaged and go on a cruise? Still making noise?
When the clutch is disengaged, the flywheel still turns, but clutch disc is not engaged to the pressure plate. I would think something is lose in the clutch assembly that is loose and touching the flywheel.
looneytoonz
Nov 10, 2007 06:14 AM
MrKrizzle
Mar 5, 2007 06:51 AM
redpeppers
12
May 18, 2006 12:49 PM
ToFu-DeLiVeRy
Jul 20, 2004 08:16 PM
