How to get the crank bolt off?
I tired sticking a flathead into the flywheel, then impact gun but still nothing
yes the motor is out of the car, Im going to try and torch it right quick.. brb
try lowering the torque setting on your gun, then set it to tighten. Then hit the bolt for 2-3 sec, then switch to loosen. Should come right off. Works for me every time. HTH
From: Commonwealth my ass This is the communist state, VA, USA
I tried with an air gun and PB blaster for about an hour and it didn't budge. Hit it with a torch until it just starts getting cherry and quickly hit it with the gun. It came off first try with that. Make sure you torque that bitch back down though, I didn't get it all the way and I was going down the road for a test drive, The car started vibrating and the battery light came on. I killed it and coasted to a stop only to find the pulley barely on, the key and alternator belt gone, and myself pissed. Good thing I know how to Jerry rig some ****... https://honda-tech.com/zerothread?id=1026040
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mulldog »</TD></TR><TR><TD CLASS="quote">perfect..its off, how about taking the head off? I have the timing belt and everything apart, how do I pull the head?</TD></TR></TABLE>
you buy a factory service manual
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MatHadder »</TD></TR><TR><TD CLASS="quote">
you buy a factory service manual</TD></TR></TABLE>
yeah the bolts need to be removed and put back in, in a sequence.
Put a long breaker bar on it, then let the breaker bar handle rest on the ground, put the car in first gear, but then push the car backwards, this will spin the engine backwards, loosening the crank bolt.
(just kidding)
(just kidding)
awjuhl
14
Jan 22, 2012 04:43 PM
youngkow
Nov 22, 2002 01:21 AM
LXguy
Jan 27, 2002 04:12 PM
1991, alternator, bolt, civic, crank, crankshaft, easy, honda, impact, installation, off, pull, si, strip, trick
