What Sould i use for fuel
Old Nov 25, 2004 | 05:46 AM
civic32958's Avatar
Default What Sould i use for fuel
I want to have a everyday driver, i have a b16 and i just want tio run about 6-7 psi , anyone know if just a fuel pump is good enough or like maybe 310 injectors , if anyone has the same set up help . Thanks
Old Nov 25, 2004 | 05:58 AM
Dragline's Avatar
Default Re: What Sould i use for fuel (civic32958)
Fuel pump is a must have,is this on a factory ecu,if so just run a FMU it should be fine.
Old Nov 25, 2004 | 07:21 AM
crispydee's Avatar
mine goes well on petrol, tried it on diesel but it does not pull as strong.
Old Nov 25, 2004 | 07:26 AM
G
sh!t happens.
Default Re: What Sould i use for fuel (crispydee)
need some kind of mangement.. Apexi VAFC hax, hondata, uberdata...etc..
Old Nov 25, 2004 | 08:13 AM
Si Shane's Avatar
Default Re: What Sould i use for fuel (G"UNIT)
I have a greddy kit w/ the 310's and a stock fuel pump. When i turn boost up to 9 psi, the motor finally leans out above 7500, so yeah. you definitly will, if the injectors/pump cannot flow enough fuel at thier maximum, or can just barely do it... what do you do when they fail (more imnportantly, what will I do, lol)
Old Nov 25, 2004 | 08:51 AM
lanojp1's Avatar
just pick up a walboro, they are under 100 bucks...
Old Nov 25, 2004 | 10:02 AM
JDMs1eeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic32958 &raquo;</TD></TR><TR><TD CLASS="quote">I want to have a everyday driver, i have a b16 and i just want tio run about 6-7 psi , anyone know if just a fuel pump is good enough or like maybe 310 injectors , if anyone has the same set up help . Thanks</TD></TR></TABLE>
6-7 psi a FMU , missing link and walbro setup works well.
Old Nov 25, 2004 | 10:30 AM
11psiTurboSI's Avatar
Default Re: (lanojp1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lanojp1 &raquo;</TD></TR><TR><TD CLASS="quote">just pick up a walboro, they are under 100 bucks...</TD></TR></TABLE>
Old Nov 25, 2004 | 12:44 PM
FOrSfEd's Avatar
Default Re: (9psiTurboSI)
walbro fuel pump and uberdata. U should be fine
AZNracerx1989
Sep 23, 2005 11:28 AM
bmoser18
Aug 16, 2005 02:30 PM
tinkfist
Apr 24, 2003 03:43 PM
E Swift
May 29, 2002 05:16 PM
2K1NBGSR
Feb 25, 2002 02:31 PM
