New fuel pump threshold psi?
Old Apr 24, 2003 | 10:41 AM
tinkfist's Avatar
Default New fuel pump threshold psi?
i am doing my research here for a custom kit and have a question regarding fuel pumps. what is the threshold psi for which i will need to upgrade my stock fuel pump to a walbro? some people say 6psi, others say 10psi.
thanks in advance.
tinkfist.....1998 ek, stock d16y8
Old Apr 24, 2003 | 11:00 AM
genop's Avatar
Default Re: New fuel pump threshold psi? (tinkfist)
depends on what kind of fuel system you are running, little more info please. AFC hack, fmu, hondata?
Old Apr 24, 2003 | 11:01 AM
turbochic's Avatar
will you have aftermarket injectors? or just add'l ones? I'm not sure on what psi, but I know for my setup, fmax at 9psi, with 2 add'l injectors, stock wont hold up for very long. I have the ERL MF2 injector controller. If you can just get the fuel pump. in best buys forum walbro 255lph for $89 shipped is a great deal!! Just also make sure you have a fuel pressure regulator that can handle the extra load.
Old Apr 24, 2003 | 11:33 AM
tinkfist's Avatar
i am going to be running 440 or 450's with the vafc hack. i know the pump is not that expensive, but i want to know why i am buying the parts, ie if i really need the parts.
thanks.
Old Apr 24, 2003 | 11:46 AM
genop's Avatar
Default Re: (tinkfist)
Personally I would get the pump in case you want to up the boost or you spike or something. But I know people that run 6psi with that set up and dont have any problems. I wouldnt go over that though.
Old Apr 24, 2003 | 03:11 PM
tinkfist's Avatar
Default Re: (genop)
thanks. any other advice on this topic before it dies?
Old Apr 24, 2003 | 03:43 PM
Bottoz's Avatar
http://www.hondata.com/techfuelpump.html
Bottoz
AZNracerx1989
Sep 23, 2005 11:28 AM
1tyme
Oct 22, 2002 12:36 PM
rjardy
Oct 14, 2002 08:15 AM
E Swift
May 29, 2002 05:16 PM
2K1NBGSR
Feb 25, 2002 02:31 PM
