Burned COIL ON S2K
Hello guy's.
Is anybody have any idea where i can buy this application like the pic below and what is the parts# that i need to ask for?
Is somebody can help me to install accel coil like pic's below?
Do i need to buy also CDI or that i can Use it on my stock ignition system just to change the wires and the coils?
Do you have diagram?
Thank you
Udi
Thank you
Udi
Because I'm running 22 psi and the coils burns like toasts..... they can't stand ... that guy has the same problem: http://forum.aempower.com/bbs/...s2000
With 10psi no problem...
Udi
Udi
That car belongs to Chris. Check out http://www.Chrisdrivesafastcar.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u_tal »</TD></TR><TR><TD CLASS="quote">Because I'm running 22 psi and the coils burns like toasts..... they can't stand ... that guy has the same problem: http://forum.aempower.com/bbs/...s2000
Udi</TD></TR></TABLE>
well in that case. i think you'll get more hits from http://www.s2ki.com ... more people on there will probably know this guy or know his current setup... as far as i know i think the ended up selling his whole setup or heard something around that...
No, you can't use the stock ignition with a setup like that. That particular one uses the AEM C2DI capacitive ignition. I run a similar setup, but I'm using motorcycle coils. You can learn all you need to know about it here:
http://www.s2ki.com/forums/ind...coils
