oil starvation anyone?
Old Nov 24, 2004 | 04:24 PM
chet's Avatar
Default oil starvation anyone?
well i purchased this longblock from a friend...vtec head is still good although the pistons/rods could be replaced...
maybe some new bearings too...let me know what you think...
Modified by chet at 1:11 AM 11/25/2004
Old Nov 24, 2004 | 04:53 PM
LSVTEC 91 Civic's Avatar
Banned
Wow... That is horrible. Rod Journals and Crank Journals are probably trashed beyond repair.
Old Nov 24, 2004 | 04:56 PM
MooreBoost's Avatar
Default Re: (LSVTEC 91 Civic)
We plan on reusing the block and building it with pistons and rods, is there anything we should look out for?
Old Nov 24, 2004 | 05:05 PM
chet's Avatar
edited...
Modified by chet at 12:12 AM 11/25/2004
Banned
Default Re: (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">We plan on reusing the block and building it with pistons and rods, is there anything we should look out for?</TD></TR></TABLE>
If you plan on reusing the block, have the main journals checked.
Old Nov 24, 2004 | 05:26 PM
Sliced Beard's Avatar
looks like someone uses Penzoil or Quaker State
notice all of the waxy buildup looking ****.....that is because of the presence of perafin wax that the few oil companies think is good to use
Old Nov 24, 2004 | 06:20 PM
hondaguyef's Avatar
Default Re: (DirtySol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote">looks like someone uses Penzoil or Quaker State
Wow! so, someone else thinks that is the reason engines that have had penzoil in them look like ****! I didn't know why but, I always shunned people from using penzoil due to that "waxy buildup" I have seen while taking apart engines that have been ran on penzoil. Thanks for the info .
Non Thread jacking info: Get those main Journals checked
Old Nov 24, 2004 | 08:11 PM
chet's Avatar
Default Re: (hondaguyef)
i just checked the main journals (just took the crank out) and there is damage.
i'm going to find another bare block...this one isn't worth using
Old Nov 24, 2004 | 08:35 PM
eg6T's Avatar
Default Re: (chet)
i dont think u should consider the guy u bought it off as a friend
Old Nov 24, 2004 | 09:10 PM
chet's Avatar
Default Re: (eg6T)
he told me the block had been seized although he never looked at it.
i'm sure he and i will work something out...and we help one another whenever possible...its not like i consider this as getting ripped off. sometimes these things happen and it wasn't really anyones fault.
Old Feb 4, 2005 | 08:38 AM
Rod.'s Avatar
Default Re: (chet)
can that waxy build up cause low oil pressure?
Old Feb 4, 2005 | 08:40 AM
mmuller's Avatar
Mad Scientist
Default Re: (redturbocivic)
no because of the oil used
Old Feb 4, 2005 | 11:00 AM
tgreaves's Avatar
Default Re: oil starvation anyone? (chet)
Tell your friend that oil changes are every 3000 miles not every 30,000 miles..
Check the crank and make sure it isnt screwed up, if so you can get a B16 crank for cheap.. Take that block to the machine shop and let the jet wash guy have fun with it..
mymeatb18"
Dec 16, 2005 06:39 PM
MugenB16A2
Mar 28, 2005 12:07 AM
EKB18BPR3
Jun 2, 2004 11:34 PM
kwik92hb
Dec 20, 2003 09:07 PM
iiilgsrlll
Jul 2, 2003 01:30 PM
