operating temp
Old Nov 24, 2004 | 06:08 AM
b18bme's Avatar
Default operating temp
So I just bought a 98 ls I love it!!! But when the car warms up it's just barely below the halfway mark on the temp guage, but when I turn on my heater the temp drops almost all the way to the cold side. Can anybody inform me on what could be cuasing this????
Old Nov 24, 2004 | 07:09 AM
burnout289's Avatar
Default Re: operating temp (b18bme)
the heater feeds off of your cooling system. this is why you don't want to turn on the heater when the engine isn't warm yet...you'll get cold air. there are two hoses connected to the firewall, one brings water/coolant from the engine and one returns it. just above your passenger's feet is a heater box that has a small radiator inside. so basically when you turn on the heater, it's like giving yourself a bigger radiator and the heat is expelled into the passenger compartment.
and this is also why you should use the heater when the car is under heavy load [like going uphill for a long time on a hot day].
never heard of it going all the way cold, tho. maybe try and let the car warm up a little longer before using the heater?
Old Nov 24, 2004 | 07:56 AM
b18bme's Avatar
Default Re: operating temp (burnout289)
Ya I drive 30 miles to work everyday and my car was completely warm. when I got to work I turned the heater on and in a couple of minutes the temp was almost all the way cold.
Can anybody help???
Old Nov 24, 2004 | 08:57 AM
PandaBear's Avatar
Maybe you have a Thermostat problem? Does your engine temp stay below mid point (like 1/4) when that happens?
Old Nov 24, 2004 | 09:06 AM
b18bme's Avatar
Default Re: operating temp (PandaBear)
yes when the heater is on it drops the heat nearly all the way to cold and it will just stay there untill I turn of the heater then it warms back up. The timing belt and water pump were recently changed before I bought the car could that have an effect?
jackhis
Jun 18, 2022 10:26 PM
Sloturd
Jan 20, 2018 12:23 PM
Stevorh
13
Feb 2, 2005 04:06 PM
b18c_ferio
Jul 11, 2004 06:20 PM
ex_crxer
Apr 6, 2003 06:52 AM
