How long does it take to do this?
Old Nov 23, 2004 | 07:45 PM
beeroh's Avatar
Default How long does it take to do this?
I bought a replacement engine from an 88 crx HF to go into my 91 HF. How long should it take and do I need pull the tranny out along with the engine?
Old Nov 23, 2004 | 07:51 PM
mr. carpenter's Avatar
Default Re: How long does it take to do this? (beeroh)
can be done in a day. pull the trans. with the motor and put back in with the motor. search search search and make sure you have all you'll need i.e. gaskets fluids.
Old Nov 23, 2004 | 07:57 PM
beeroh's Avatar
Default Re: How long does it take to do this? (mr. carpenter)
Are there any precautions that I should take before and during the swap?
The motor I am putting in hasn't been ran in two years, is there anything I should do?
Old Nov 23, 2004 | 08:09 PM
it does'nt sound like you have done one before? is someone going to help you? it takes us a day or so because we've done like 5 of them.
Old Nov 23, 2004 | 08:11 PM
beeroh's Avatar
Approximately how many hours would it take me?
Old Nov 23, 2004 | 08:12 PM
you by yourself?
Old Nov 23, 2004 | 08:15 PM
beeroh's Avatar
yes, by myself
Old Nov 23, 2004 | 08:17 PM
EFHondaRue's Avatar
If you have all the right tools and an engine hoist it shouldn't take you more than 4-6 hours depending if you come across any unexpected set backs. That is of course if you have had experience with swaps. When I did my first swap by myself without any knowledge it turned out to be an all nighter. So find a couple of friends and have fun. It isn't difficult. Just a little time consuming if you don't know what you're looking for to pull a motor.
Old Nov 23, 2004 | 08:20 PM
not to sound gay but you should really have some one help you just for safety reasons. it also helps to have a extra set of eyes when pulling the engine out and putting it in. not that i think you can't do it. it'll go alot slower though. if you got to do it that way then you have to. this board will be an invaluable tool to you. be patient, don't get ahead of yourself and if you are'nt sure then come here and ask. good luck you can pm me if you need to. it's a pretty straight forward swap. i don't think you'll have any wiring to do.
Old Nov 23, 2004 | 10:02 PM
Dave421's Avatar
Did you get a new transmission as well? The 88 has the 20-21? spline shaft and the 91 won't (22? can never remember)
Old Nov 24, 2004 | 02:50 PM
beeroh's Avatar
Default Re: How long does it take to do this? (Dave421)
can someone verify this 21-22 spline shaft info.
Old Nov 24, 2004 | 02:57 PM
zulued's Avatar
dont worry about the spline counts just use your origional clutch and flywheel..
the one that is on the 91 motor...
scarponze
audiopipematt88
Nov 13, 2008 06:44 PM
g_tech9
Classic Hondas
Aug 8, 2007 06:44 AM
jdm_crx91
Oct 13, 2006 01:05 PM
tcwcrxhf
Jun 27, 2004 04:42 PM
ironchef25
10
Oct 29, 2003 09:14 AM
