Questions about axles
I own a 96 honda civic coupe with a h22a jdm lsd I just replaced the pasenger axle. I am running a 1990 accord shaft with 90- 93 integra non abs axles. The reason I only replaced one of them is because the other one didn't break or tear. Im noticing that when I turn left my car shakes real bad. I checked it out and gave everything a better tie. everything was put on correctly. I just need some feed back. I broke my passenger side axles at the track. Could it be that my drivers side axles is messed up and need to be replaced. Or can it be the tires worn or aligment, I just dont know???????????????????????Thanks
are ur wheels on all the way? something isnt fitting right imo...go over everything and double check.
here is a guide you can use as a checklist.
https://honda-tech.com/zerothread?id=382564
