power window doesn' t go up need help
Old Nov 23, 2004 | 03:06 PM
Siegfried's Avatar
Default power window doesn' t go up need help
I've been able to remove my driver side power window motor and change it, I also replace the fuse but it only goes down, and doesn' t go up.
Does anyone know where the prob comes from ?
window master switch, relay ? or window regulator ?
Thanks
Old Nov 23, 2004 | 09:31 PM
PrettyLude's Avatar
i would suspect the window master switch, i had the same problem on a different vehicle and turned out to be that
Old Nov 24, 2004 | 12:48 AM
SKDRCR's Avatar
Default Re: (PrettyLude)
There's a good chance that the soldering where the wire meets the switch
came loose. See if it's disconnected and resolder it
Old Nov 24, 2004 | 01:25 AM
Siegfried's Avatar
I'll check, does anyone know where I can get these parts ?
I've watch on majestic, I don' t find them.
Thanks
Old Nov 24, 2004 | 02:59 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: (Siegfried)
What year is your car?
I say it's probably the switch or the regulator.
did you see any shuttering/bogging when the window's going down?
Old Nov 24, 2004 | 08:25 AM
Siegfried's Avatar
Default Re: (Sticky Tires)
Nope no bogging when going down.
what would it be if it' s bogging ?
Old Nov 24, 2004 | 08:27 AM
* B A N N E D *
The window regulators. I had to replace both on my 2000 SH under warrany.
Bog, slow coming up was the symptoms.
Old Nov 24, 2004 | 12:00 PM
Siegfried's Avatar
My prob comes from the switch, I' ve made test on the connector after removing the switch and motor works on both sides.
Anyone know on wich section of Majestic or San Leandro Honda I can find this part.
I can' t find it. it doesn' t appear on the door window page.
Thanks
Old Nov 24, 2004 | 01:32 PM
SKDRCR's Avatar
http://slhondaparts.com/browse...INING
I don't know what year your car is, but it's in the interior section
Old Nov 24, 2004 | 01:53 PM
Mr.Dew's Avatar
Yep, it's Eric.
check the fuse and connections before anything like they said above. if you still have the receipt for the motor you should take it to honda, cuz you still would have warranty on that motor if you bought it less than a year ago. it sounds like the motor because mine did that twice in one year even with a brand new motor. it might turn out it's the regulator though, or both.. sometimes one takes the other out with it.
Old Nov 24, 2004 | 11:11 PM
Siegfried's Avatar
Default Re: (oNeMoBB1)
like I said, I found that the prob was coming from the switch, I' ve remove it and plug wires between them and turn on the contact, my mortor works on both sides.
Thanks for the link SKDRCR, I didn' t saw this page on the S model pages,
I got a 93 Prelude S.
Old Nov 25, 2004 | 12:13 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Siegfried &raquo;</TD></TR><TR><TD CLASS="quote">
It's there. Interior, Front door lining.
mayurji1
Jun 9, 2014 03:49 AM
jayjazmin
Honda CR-V & Element
Sep 6, 2013 01:39 AM
bighoss77
Aug 16, 2012 08:44 PM
rwp011
Dec 16, 2011 05:13 PM
deetzracing
Jan 16, 2011 08:46 AM
