Are OBD1 and OBD2 Dizzy's swapable ?
Old Nov 23, 2004 | 02:38 PM
98TypeSH's Avatar
Default Are OBD1 and OBD2 Dizzy's swapable ?
Is the difference only in the internal/external ignition coil ? Or are OBD1 the old Gear style as on many older cars ?
Just trying to swap a diff dizzy to see if i can get this check engine light, and i have access to an OBD1 but not OBD2.
Also, if it makes a difference im on a OBD1 P72 ECU.
Old Nov 23, 2004 | 02:41 PM
4bidden's Avatar
Default Re: Are OBD1 and OBD2 Dizzy's swapable ? (98TypeSH)
No they are not. OBDI has sensors in it that the OBDII doesnt (CYP etc.).
Old Nov 23, 2004 | 05:31 PM
98TypeSH's Avatar
Default Re: Are OBD1 and OBD2 Dizzy's swapable ? (4bidden)
you sure its not the other way around? currently i am throwing that code 9 CYP Sensor, that is supposed to only be in OBD2 Dizzy's. Since im running an OBD1 computer im thinking i can swap over if just the external/internal ignition coil are the only differences.
Old Nov 23, 2004 | 05:37 PM
prelittlelude's Avatar
from my past experience the obd1 and obd2a dizzys all have the same sensors but the pickups read at different resistances, hence they are different , also the extra sensor that the obd2 computer looks for is called the crank speed flucuation sensor. atleast this is the case on the 1996 prelude..
i tried runing an obd2 dizzy and threw all kinds of codes
i also have a firned who is trying to run a obd1 dizzy on a 1996 honda prelude ecu, and he is getting random misfire codes and the dizzy is suspect, as the obd1 pickups have a lower resistance reading than those of the obd2
hope that helps
mobeast808
Jan 26, 2025 09:18 PM
redline870
Nov 5, 2008 05:19 PM
b16greenmachine
Jun 2, 2006 07:52 PM
ludests
Nov 14, 2003 10:23 PM
torq2k
Oct 28, 2003 10:28 AM
