Timing Belt/Water Pump/Cam Gears Install
Does anyone know where I can get training on how to do this?
I live in VA. If anyone in VA is reading this, has the tools and experience for this install, and would want some money to help me do this, let me know.
Thanks
Thanks
very true. the hardest part is that crank pulley bolt. but i didnt have n e problems take n mine off. came right off with an impact gun.
http://www.c-speedracing.com/h...t.php
Yep I just did my timing belt for the 1st time. Along with tensioner and waterpump. Hardest part was getting the crank pully off. I had to buy a better imact gun that was rated for mre torque. My old one must have been a Honda of some kind
. Then after that the only thing that I had trouble on was lining everything back up. Took a couple of times. But it was my first time ever doing a timing belt.
Tell me are you finding two small keys holding crank pulley assemblies in obd1 engines and only one key in obd2 engines? The reason I ask this is they show only one key required that has the same part number as the obd1 engines at delrayacura. Why 2 seperate small keys and not just one long one holding those 2 big *** pulleys on to the crank
But was this obd1 or obd2 and if only one key to hold both the crank pulley and the dampener it must be a looong *** key then????? Cause the part number for the obd1 key and obd2 key is the same and it is a small key, one key per pulley.
stackz
Oct 24, 2012 02:45 PM
4kgst
Sep 15, 2009 01:11 PM
