b18c in 91 rex fuel pump not kicking on
Old Nov 23, 2004 | 09:51 AM
n8barton's Avatar
Default b18c in 91 rex fuel pump not kicking on
its in the title, i have swapped the entire car harness twice, (engine and body) swapped multiple main relays, have three ecus, pwo and two pr3s, have check and redone the grounds, but still when i turn the key, the check engine light works, but the fuel pump does not kick on. if i straight wire the pump, it kicks on. any suggestions OTHER than what i listed???
Old Nov 27, 2004 | 05:17 PM
smokey2.0's Avatar
Default Re: b18c in 91 rex fuel pump not kicking on (n8barton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n8barton &raquo;</TD></TR><TR><TD CLASS="quote">its in the title, i have swapped the entire car harness twice, (engine and body) swapped multiple main relays, have three ecus, pwo and two pr3s, have check and redone the grounds, but still when i turn the key, the check engine light works, but the fuel pump does not kick on. if i straight wire the pump, it kicks on. any suggestions OTHER than what i listed??? </TD></TR></TABLE>
have you checked the main relay?, and the ecu fuse on the passenger side of the engine bay?
Old Nov 28, 2004 | 07:39 AM
primeredbeast's Avatar
alternator fuse under the dash trust me on this one if you have a walbro you will have to go to a bigger alternator fuse i believe to a 15
Old Nov 28, 2004 | 12:21 PM
smokey2.0's Avatar
Default Re: b18c in 91 rex fuel pump not kicking on (primeredbeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primeredbeast &raquo;</TD></TR><TR><TD CLASS="quote">alternator fuse under the dash trust me on this one if you have a walbro you will have to go to a bigger alternator fuse i believe to a 15</TD></TR></TABLE>funny, i been running a 255 walbro pump for over 2years. i only had that 14 fuse blow once, that was over the weekend while istalling my ukmd cluster i think i crossed some wires, and that's why it blew.
oresama
31
Jan 19, 2025 10:47 PM
Djfox
Apr 20, 2018 11:13 AM
mihaelrosas
May 28, 2007 06:20 PM
Siegfried
Aug 21, 2006 11:17 AM
5genhatch
Aug 6, 2005 05:39 AM
